4 speed muncie problems
Okay where do I start,
Heres what happend I was driving and third gear just started to grind when up shifting or down shifting, so I thought I could make it home in 1,2,4. I get to the last stop light before my house and I pull up to it in 4th (didn't down shift to slow down) and it was stuck in 4th, so the light turns green and I decide to ride the clutch and go for it(yes I know bad for the clutch), but I make it home. I then a couple hours later i find out to get it out of 4th gear, I need to rock the car back and forth while someone trys to get it out of gear by wiggling the stick. Did it and it worked. The next day I was going to bring it to school (auto shop)and put it up on the lift to see what the problem was. I drive it half way there and 4th gear gets stuck again so I stop and push my car out of the middle of the road. The clutch also went to the floor becasue the rod that goes to the clutch fork bent after it got stuck in 4th(fixed wasn't a problem). As im getting towed the rest of the way to auto shop I have the car on to use the power steering. Its in 4th with the clutch out(cluth not working becasue of bent rod) and it does this accasional grind, not sure if its when I go over a bump(mabey linkage im thinking.) I get it on the lift, I move the linkage underneath by hand and it comes out of fourth but still wont go into third. When I move the 4th and 3rd linkage by hand the 1st and 2ndl linkage moves with it. I couldn't see any binging so we thought it was internal. I tow the car home drop the tranny and pull off the linkage and inspection cover. No chiped gears and what im guessing are the brass synrows (brass rings next to the gears) are fine. I play with the gears making sure nothing is seized. Put it all back together and it goes into 3rd and shifts fine. I then take off the shifter to see if that whats making it shift two linkages at once. It's the shifter moving 1,2,3, and 4 all at the same time making my tranny bind and not go into 3rd. I put the tranny with the shifter back together as I had takin it out of the car. I then saw when I shifted from 1st to 3rd it would leave 3rd gear in gear while going into 1st and vise versa. I've sorta narrowed it down to the shifter. I think thats my problem but I don't know how to fix it. If you can't understand a part of this tell me and I will try to explain it better. Help me please! (65 elcamino not original tranny don't know when the new muncie was put in). |
First off did you have the linkage on when you checked the shifter? Second Muncies are bad about the cases wearing at the front bearing area. Since you stated trans has apparently been rebuilt this could be the case, the syncros could have been the only thing replaced and the old bearings left in. Also you need to pull the side cover back off and check the detent springs at the shifter forks and see if they are pulling the notched arms back into place. This sounds like a combination of things and may be just as much internal as well as external. Check this and get back to us and we'll go deeper if necessary.
Had the same problem.
I would follow the advice previously given. I have a Muncie and had the same problem and discovered the following.
1. The little round bushings that fit in the shift leavers, that the shift rods fit into were binding. I removed these, took a dremel tool and ground just a little off the inside diameter. Put a dab of wheel bearing grease on each one and re-installed. 2. The shifter I had was out of adjustment. On my shifter there was a way you could align all the shift arms coming out of the shifter and install a 1/4 inch alignment tool. As far as I know all shifters have some type of adjustment. After doing the above, I never had a problem with gear shifting again. While you have it up there you might check to be sure the gear lube is up to the correct level inside the transmission. Hope this helps. |
definateley follow the advise from above; and when it gets stuck, try violently shaking the shifter around. I had a Hurst Comp Plus that was worn out and when they get that bad - just ship to the factory and have it reman'd. I think if you can stick any more than .030 between the shifter plates it is time. Also check you clutch and make sure it is adjusted correctly. It might not be engaging correctly, making the synchos turn to dust.
good luck cj |
Yes it is Hurst competition plus, I removed the cover again after reading a tranny book and the stud that goes into the inspection cover holding the detent cam had fallen out. All the parts were laying in the bottom of the transmission in tack surprisingly. I taped the stud back into place and put the detent cam back together.
I put the tanny back in my car today and it worked like a champ. Thanks |
