4 speed rock crusher i.d. help - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2002, 11:41 AM
slider in wa's Avatar
Slider in Wa.
Post 4 speed rock crusher i.d. help
Hea guys, where can i look up cheverolet transmission numbers? Trying to i.d. what year and proper i.d of this tranny is before i put it on the for sale site. Please advise Slider in Wa.
klberry212@yahoo.com
#3851326 gear box
#381707 cover oplate
#3846429 tail shaft
Thanks in advance.
Old 09-01-2002, 06:57 PM
MI2600's Avatar
Member# 3287
Post
I found a 3851325 main case, with a 707 cover and a 429 extension housing. Those numbers were used for all Muncie's (M-20, 21, 22) in '65 Chevy's. The M-20 had a 2.56:1 1st gear. The M-21 and 22 had 2.20:1 1st gears. I don't have the expertise to differentiate between the 21 and 22. It had to do with the slant of the gears. Maybe someone else out there knows.
Old 09-02-2002, 11:00 PM
Post
Rock Crusher had "no" ring cuts on input. This was first indicator. Striaght cut gears and no "anti whine" devise on front of cluster gear.
Old 09-05-2002, 04:20 AM
SAE Member; ASE Master Cert
Post
Also, the rock crusher has a larger yoke - same size as used on Turbo 400.
