-   -   4-speed in and running! (http://www.hotrodders.com/forum/4-speed-running-232632.html)
31ROC 05-07-2013 05:42 AM
This past winters project near completion...(transferred 700r4 to Muncie 4 speed). Car runs and shifts, but definitely needs clutch pedal adjustment. Since this is my first hydraulic T/O bearing, where should the clutch start engaging? How far should the pedal go down?
These are the under floor pedals, and I feel I may have the clutch pedal set to low to start, as I push it down, it gets real "flat" on me. Meaning--- when I push the clutch pedal down its starts at about 45* angle to the floor, and will go down to almost flat with the floor making it quite uncomfortable to the leg and foot. Maybe I need to lengthen the adjustable rod in the master to be longer, moving the pedal starting point towards the seat more?
vinniekq2 05-07-2013 07:10 AM
sounds like it could move higher for your comfort.Its your car,where do "you" want enguagement?
31ROC 05-07-2013 08:56 AM
just wasnt sure if hydraulic clutches were different in adjustments than conventional.....prob gonna extend the threaded rod on linkage to get pedal at higher start point.....wonder if the "travel" will be too long then and hurt master?
