4-speed in and running! - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-07-2013, 06:42 AM
31ROC's Avatar
This past winters project near completion...(transferred 700r4 to Muncie 4 speed). Car runs and shifts, but definitely needs clutch pedal adjustment. Since this is my first hydraulic T/O bearing, where should the clutch start engaging? How far should the pedal go down?
These are the under floor pedals, and I feel I may have the clutch pedal set to low to start, as I push it down, it gets real "flat" on me. Meaning--- when I push the clutch pedal down its starts at about 45* angle to the floor, and will go down to almost flat with the floor making it quite uncomfortable to the leg and foot. Maybe I need to lengthen the adjustable rod in the master to be longer, moving the pedal starting point towards the seat more?
Old 05-07-2013, 08:10 AM
vinniekq2's Avatar
sounds like it could move higher for your comfort.Its your car,where do "you" want enguagement?
Old 05-07-2013, 09:56 AM
31ROC's Avatar
just wasnt sure if hydraulic clutches were different in adjustments than conventional.....prob gonna extend the threaded rod on linkage to get pedal at higher start point.....wonder if the "travel" will be too long then and hurt master?
1951 Chevy business coupe, replaced the 3 speed with a 4 speed transmission. EricKessel Transmission - Rearend 1 08-08-2011 09:35 PM
Possible Cure for SBC running hot at highway speed 75gmck25 Engine 5 01-31-2011 08:03 AM
Is there any advantage in running a BG speed demon over an edelbrock performer carb? batman09 Engine 49 07-02-2008 08:51 PM
4 speed auto-5to6 speed manuel R4MM Transmission - Rearend 6 05-26-2007 10:54 AM
Next upgrade for the money pit. A 4-speed. Which 4 Speed is the best choice? killerformula Transmission - Rearend 3 05-26-2004 04:54 AM
