4 Speed Saginaw - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-06-2009, 03:54 PM
4 Speed Saginaw
Ok so i recently had one of the ears on my transmission welded back on from previous damage. Before I took it to have it welded, I took off the side cover to visually inspect the gears and internal parts. Although I am not an expert, everything seemed to be in good shape. However, once I took the cover off and held it upside down, there was a ball-bearing rolling around in the cover. It was about 1/4" in diameter, and my dad suspects its some sort of detent ball for the shift forks?! I really need to install this replacement tranny ASAP, if anyone has any exploded diagrams or general information as the where the bearing belongs I would highly appreciate it!!
Old 11-07-2009, 07:30 PM
Wiki Edits: 27
shifter
Usually there are spring loaded ball bearings that click into the notches in the inside of the shifter arms... some performance kits replaced the spring with a solid piece of rod. If you take off the outside lever you can remove the mechanism to the inside check to see if you have the pieces in the right place. I have seen diagrams of floor shift kits that had an exploded view of the trans. don't know where.
Old 11-07-2009, 07:51 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Maybe this can help. http://www.chevytrucks.org/tech/ovdrive2.gif .......Cole
Old 11-10-2009, 06:32 PM
It's probably the reverse detent ball. If the reverse lever is removed from the outside of the cover, the spring inside the detent hole will push on the lever, releasing the ball that's on top of the spring.
2 speed VS 3 speed DUN4ME Transmission - Rearend 2 07-12-2009 06:47 PM
saginaw 4 speed tomasmika Transmission - Rearend 3 09-03-2007 01:09 PM
Need some advice on a saginaw tran's bowtieorbust Transmission - Rearend 1 10-24-2004 01:59 PM
Saginaw trans ? 4 speed but with OD hosep Transmission - Rearend 16 10-19-2004 09:22 PM
Saginaw 4 speed, how much can it take? Old School Nut Transmission - Rearend 10 08-05-2004 05:59 PM
