Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4 speed saginaw shifter problem
Old 12-01-2012, 06:56 PM
poncho62's Avatar
poncho62 poncho62 is offline
Wiki Edits: 5
In neutral are all your levers lined up exactly?..Hurst shifters, at least the ones I used to have had a hole through the case and the 3 levers, so that you could in neutral put a pin through and then adjust your linkages . That would put the gate even so it would shift properly when going from 2nd to 3rd......Hope I explained that right
