4 speed saginaw-what gear should i use - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-02-2013, 06:50 PM
i have two saginaw 4 speed transmission one 2.54 first gear and the other has 3.50 first gear... building a 1930 model a highboy on 32 rails, 350 sbc, 9" ford rear 3.50 posi, 31" tire diameter.. not alot of horsepower and the car is pretty light.. what gears would work best with this setup ? (will be driving on the highway to car shows and a little bit of city driving
Old 04-03-2013, 08:07 AM
OEM's used to base their calculations for "Starting Line Ratio" or "Total Mechanical Advantage" on the formula Rear Axle x 1st Gear = 9. So, divide 9 by 3.50 and our theoretical 1st gear would be 2.57.
Use your 2.54 1st gear Sag; its has a better ratio spread and more strength than the 3.50 1st gear one
The Following User Says Thank You to AutoGear For This Useful Post:
ONEGALONLY (04-03-2013)
Old 04-03-2013, 08:49 AM
just what i needed.. explained well,, thanks
Old 04-03-2013, 09:06 AM
No problem!
Post pics of your highboy sometime
Old 04-03-2013, 02:09 PM
pic of hiboy
Originally Posted by AutoGear View Post
No problem!
i have one pic in my photo album.. will get more on soon
saginaw 4 speed tomasmika Transmission - Rearend 3 09-03-2007 01:09 PM
Saginaw 4 speed, how much can it take? Old School Nut Transmission - Rearend 10 08-05-2004 05:59 PM
Saginaw 4-speed NewOldBlue Transmission - Rearend 1 02-17-2004 02:49 PM
Saginaw 4-speed NewOldBlue Transmission - Rearend 0 02-17-2004 01:07 PM
saginaw 3-speed ? bowtieorbust Transmission - Rearend 2 01-12-2004 09:54 PM
