4 Speed Top loader
what would you you say would be the best 4 on the floor tanny for a I6 200?
I edited the thread title to provide more information. I took a guess you were talking about a Ford
At the Bonneville Salt Flats, first gear is known as 130 mph. |
few options. originally, a Dagenham ( SP ) 4spd was optional. Late 70's also brought the 3+OD toploader, used in Granada's behind the 6 and the SROD 4spd which will also work.. I'd use the SROD or the Granada trans. Some F-150's also used the 3+OD toploader and they should also work
4 SpeedTT
Is the 4 Speed Toploader Transmission only for V8s? If so what could i use?
Thx |
Not sure about your year of car, but the Falcons with v8s up to 65
used a Borg Warner t-10 for Ford applications. 4-speed were not used with the 6cylinders that I am aware of. My 65 Ranchero has a Borg Warner in it-----kinda half heartedly looking for someone to rebuild the shifter----not a common trans in the Falcons I guess. Mustangs of the same era used the toploader and they are virtually a Falcon with different fenders. The shifter comes up in the center of the hump in the mustangs The shifter comes up just to the left of the hump in the Falcons, so, the two cars do not use the same shifter. |
The 6cyls got the Dagenham 4spd as an option. the basic 3.03 3spd was the base transmission. The Dagenham is said to have wooden gears because of it's light duty.. The toploader was used from '65- on in V8's with 4spds. it will work with the 6cyl, and the 3+OD variation was very common in 6cyl Ford Granada's
| speedometer cable 4 speed top loader | 001mustang | Transmission - Rearend | 1 | 03-30-2011 09:37 PM |
| can i put a top loader four speed i my 1972 plymouth duster | 72twister360 | Transmission - Rearend | 6 | 12-10-2010 09:05 AM |
| please help identify my ford top loader 4 speed | randyhemi | Transmission - Rearend | 16 | 07-06-2009 08:10 PM |
| Jeep shifter for ford top loader 4 speed trans | diesel dick | Transmission - Rearend | 3 | 03-04-2009 08:12 AM |
| 4 speed top loader problems | fortypickup | Transmission - Rearend | 1 | 08-19-2007 02:09 PM |
