4 speed top loader problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2007, 12:19 PM
fortypickup's Avatar
Wolf in Hot Rodders upholstery
Last journal entry: Tail light issues
I purchased a rebuilt top loader for a 65' mustang project. The tranny shifted fine before I installed it in the car. When I was installing it, the tranny slid into the clutch just fine, until the last 1 inch or so, it had to be pulled to the bell housing with the 4 bolts, and it went hard the whole way! I got in a hurry to fire up the new crate motor and I did not have a yoke for the tranny, so like an idiot I started the engine without filling the tranny! I thought it was out of gear but unfortunately the linkage was hooked up misaligned, and it turns out it was in gear! I ran the motor for about ten minutes! I have since filled it with gear oil & have ran the motor. It seems to be stuck in gear, the yoke stops spinning when I push in the clutch. The shifter seems to slide into all gears except 1st. DID I TRASH THE TRANNY? HELP!!!!!!!!
Old 08-19-2007, 02:09 PM
aka Duke of URL
It is going to have to come out to check the pilot bushing/bearing and pull the cover.
Top loader speedo gear selection pooshooter Transmission - Rearend 1 08-22-2006 04:49 PM
stall speed? 70chevyc10 Transmission - Rearend 6 11-23-2004 02:51 PM
vinyl top question frydz1985 Body - Exterior 3 10-21-2004 02:27 PM
Ford Top loader Transmission-HELP! Mike Pomerantz Suspension - Brakes - Steering 4 10-20-2003 06:17 PM
Top Speed 69 chevelle SS Hotrodding Basics 30 10-20-2003 02:24 PM
