4 speed toploader - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2009, 11:19 AM
jgh64pkup's Avatar
Last journal entry: new et streets
4 speed toploader
does anyone know where to find a bellhousing that adapts a 4 speed toploader to a sbc i also need all of the other parts to adapt it
what kind of tq and hp will it take
any help would be great, thanks
Old 01-15-2009, 12:20 PM
Holly-Roller's Avatar
*special* member
Try Lakewood.
Old 01-15-2009, 12:54 PM
jgh64pkup's Avatar
re: 4 speed toploader
i found one from lakewood part# 15060
what other parts would i need
Old 01-15-2009, 02:00 PM
*special* member
I'm not sure, I got a Lakewood bellhousing to adapt my 350 Chevy to my Ford T-5, fit great and came with all hardware, as well at the starter plate. I'm not too familiar with the toploaders, so I don't know if you need to change input shafts.
Edit: In order to fit the Ford T-5 into my Chevy 350, the input shaft required a bit grinded off of the tip (About a 15 minute job done right)
Old 01-15-2009, 02:22 PM
jgh64pkup's Avatar
does anyone know anything about a 4 speed toploader
Old 01-16-2009, 04:47 PM
jgh64pkup's Avatar
i just looked at the transmissions i have today and found out they were 3 speeds hadn't looked at them in a couple of years
can anyone identify this number off of the trans RAT-G1
i also have another one but cant read the numbers
neither have shifter mounting holes
Old 01-18-2009, 09:42 AM
woodz428's Avatar
Troll Hunter
Most top loaders and the Ford 3 speeds use the same pattern. There are a variety of adapters, besides complete bellhousings available , Transdapt as well as others are available. They were pretty common at one time and may be able to locate a used on from some of the Vintage speed shops. The clutch plate will need changed, but not sure about the rest.
350 or 383 Stroker? my350camaro84 Engine 19 07-30-2012 07:44 AM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 12:48 PM
Th350 to 4 speed auto conversion Bandit1980 Transmission - Rearend 3 12-29-2004 07:41 PM
Stall Speed? drlindz Transmission - Rearend 2 08-25-2003 02:40 PM
difference in 2 speed to 3 speed auto? HemmiGremmie Hotrodders' Lounge 2 12-17-2002 05:31 AM
