4 Speed what is it - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-17-2010, 04:29 AM
sqzbox's Avatar
My pipes are my music
I believe my 66 LeMans came out with one also behind the 326 cu. in.
  #17 (permalink)
Old 12-19-2010, 08:29 AM
3rdmember
Originally Posted by Centerline
You're correct.....My bad. No Corvettes. They did came in Camaros, Chevelles, Monzas, Novas, GMC Caballaros, Pontiac Firebird, TransAm, Sunbird, Sunfire, early Lemans, Tempests, and a host of Buicks and Oldsmobiles. Alll applications were small block V8's 350 cu. in or smaller, inline and V6's, and in some cases 4 cylinders.
you forgot vegas
  #18 (permalink)
Old 12-19-2010, 08:44 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by tomslik
you forgot vegas
Saginaw trans was used in Vega to replace that Opel trans that was 100% garbage.
  #19 (permalink)
Old 12-19-2010, 08:59 AM
3rdmember
those opels wern't THAT good....73-up vegas had the saggynoss'
btw, once upon a time i remember seeing an article for using a saginaw 3 speed OD and puting it on the back of a saginaw 4 speed...
uhh, good luck finding the 3 speed OD trans...
haven't seen one since '79 when i pulled it out of a 66 chevelle...
  #20 (permalink)
Old 12-19-2010, 04:34 PM
Wiki Edits: 49
I have a buddy that put one of the 3 speed w/OD behind a 454. Not something I would do and the jury is out on whether it will hold up to any hard use. I have a Saginaw 4 speed behind the hemi in my deuce. It was out of a truck as I had to change the input shaft bearing retainer to the smaller size. That one will not see extremely hard use though.
And yes the Saginaw did find its way into Vegas and a LOT of other GM vehicles as well.
  #21 (permalink)
Old 12-19-2010, 08:21 PM
New Member
I am wondering what is the real name. Saginaw or Saganaw?
  #22 (permalink)
Old 12-19-2010, 08:34 PM
sqzbox's Avatar
It got it's name from the plant in Saginaw Michigan like Muncie indiana.
  #23 (permalink)
Old 12-19-2010, 09:56 PM
Wiki Edits: 49
Whoever thought of naming a town in Indiana after a transmission was brilliant! Chevy guys will never forget it.
  #24 (permalink)
Old 12-20-2010, 05:40 AM
sqzbox's Avatar
Actually, the town came first. Thank god GM didn't put a tranny factory in French Lick!
I can hear the conversation now at the cruise in. "Hey man, check out my french lick 4 speed" LOL
  #25 (permalink)
Old 12-20-2010, 09:07 AM
Wiki Edits: 49
Or Intercourse, Pennsylvania!
350 or 383 Stroker? my350camaro84 Engine 19 07-30-2012 07:44 AM
Speed Week 2010 photography plugphotography Hotrodders' Lounge 8 07-13-2010 12:36 PM
what does a speed censor do? notmrgoodwrench Engine 1 06-15-2005 05:27 PM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 12:48 PM
Stall Speed? drlindz Transmission - Rearend 2 08-25-2003 02:40 PM
