4 Speed what is it - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-26-2010, 09:31 PM
4 Speed what is it
Does anyone know what this tranny is , i am looking at maybe putting it behind 375 horse SBC and a 3200 LB car, car is now a 350/350 auto, dont know alot about standard trannys, oh ya it has 3 rings on the input shaft
Jim
ID:	50397   Click image for larger version
ID:	50398   Click image for larger version
ID:	50399   Click image for larger version
Old 11-26-2010, 09:51 PM
big gear head's Avatar
High Performance Rear Ends
It's a Saganaw 4 speed. Is that bracket welded to the top of the tail housing?
Old 11-26-2010, 11:09 PM
ericnova72's Avatar
More for Less Racer
saginaw 4-speed, don't expect it to live long if you beat on it alot.
Old 11-27-2010, 01:23 AM
yea it will survive if your nice to it. If you want to have something a LITTLE more forgiving try finding a M-22. but then again those are like gold now a days.
Old 11-27-2010, 09:27 AM
sqzbox's Avatar
My pipes are my music
4sp install
What ever you do, DON'T forget the pilot bushing.
Old 11-27-2010, 03:05 PM
Wiki Edits: 49
The Saginaw can easily handle anything under 350 hp. They came stock in Camaros and even early Vettes. Don't put one behind a big block or anything with big hp if you intend to do any racing. I have one behind the early hemi in my deuce and it will easily handle the hp and torque for normal and even spirited street driving because its a light car. Big hp, and a heavy car will spell disaster for the Saginaw. Best go with the Muncie if that's what you intend to run.
Centerline
HotRodsAndHemis.com
"Instructions are just the manufacturers opinion of how it should be put together". - Tim Allen
Old 11-27-2010, 03:10 PM
I've never seen a Saganaw in a Vette. I've seen the cast iron case T10s in them, but not the Saganaw.
Old 11-27-2010, 05:31 PM
Saginaw
Well guys it wont be over 375 and probably closer to 350 HP side of it , Its going in a 78 Caprice Aero Coupe , 10 bolt Eaton posi and 456 gear set , wont be much of a HWY cruiser just BLVD cruiser, and any advise is always welcome
Thanks
Jim
Old 11-27-2010, 06:17 PM
Wiki Edits: 49
You're correct.....My bad. No Corvettes. They did came in Camaros, Chevelles, Monzas, Novas, GMC Caballaros, Pontiac Firebird, TransAm, Sunbird, Sunfire, early Lemans, Tempests, and a host of Buicks and Oldsmobiles. Alll applications were small block V8's 350 cu. in or smaller, inline and V6's, and in some cases 4 cylinders.
Old 11-27-2010, 06:53 PM
They were also used in the G body cars.
Old 11-28-2010, 01:28 AM
junior stocker's Avatar
My 76 edition CHILTONS notes Saginaw 4-speeds were also used in 69-76 Corvettes; probably even later, but I don't have any later books. The Saginaw 4-speed of the original poster is going to be the light weight version, Vega/Monza style, with narrower gears. Take it easy, don't beat on it, and drive it like grandma, and it will last a while.
Old 11-28-2010, 08:00 AM
302 Z28's Avatar
Just helped a friend do some work on a 74 Vette that was a Mecum Auction purchase. Replaced both the original engine and trans. The old trans was indeed a Saginaw 4 speed.
Vince
Old 11-28-2010, 08:54 AM
Wiki Edits: 49
Vince
That's interesting. When big gear head mentioned he had never seen one in a Vette I rechecked my documentation and it didn't list any. I thought I had been told some did make it in Vettes but couldn't find the info. I guess this is one of the VERY rare cases where my memory was better than my documentation. At my age that almost NEVER happens.
Centerline
HotRodsAndHemis.com
"Remember, if you didn't put it together with your own hands, its not really yours." - Tim Allen
Old 11-28-2010, 02:38 PM
Notice I didn't say that they were never installed in a Vette, just that I had never seen one. I guess I just haven't been under the right Vette yet.
Old 12-16-2010, 10:29 PM
3 rings indicate a 3.50:1 low gear, which has the least torque capacity of the bunch. Don't beat on it too hard, especially in low.
350 or 383 Stroker? my350camaro84 Engine 19 07-30-2012 07:44 AM
Speed Week 2010 photography plugphotography Hotrodders' Lounge 8 07-13-2010 12:36 PM
what does a speed censor do? notmrgoodwrench Engine 1 06-15-2005 05:27 PM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 12:48 PM
Stall Speed? drlindz Transmission - Rearend 2 08-25-2003 02:40 PM
