4 wheel disc brake plumbing - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2008, 07:17 PM
tc33's Avatar
Stuck in the 30's
Last journal entry: Where it came from and how I got there - a short Summary
Getting ready to plumb the brake system on my project. The kit I got came with proportioning valve (only 1) and residual valves ( 2 - 2lb) 1 for front and 1 for rear brakes. The master cylinder is mount to the frame, not in the engine compartment.
Based on my understanding the proportioning valve goes on the rear circuit with one of the residual valves. Am I correct in this ?? If so, does the residual valve go closer to the master cylinder than the proportioning valve ???
Old 02-20-2008, 07:24 PM
life is a temporary assignment
Hope this help's you out.
Old 02-20-2008, 07:38 PM
31 five window
Last journal entry: grill and rear end
There is your answer. The residual valve goes before the proportioning valve.Way to go NEW INTERIORS. I have to get you to show me how to put pics out of a catalog like that. I have no clue.
Old 02-20-2008, 07:46 PM
tc33's Avatar
Stuck in the 30's
Thank you
Appreciate the responses so quickly. I need a sanity check every so often.
http://www.hotrodders.com/forum/newr...te=1&p=933154#
Smilie
Old 02-20-2008, 07:49 PM
Old 02-20-2008, 07:57 PM
31 five window
tc33,I don't understand why you posted those red letters,it just goes to new post.
1964 F100 Disc Brake Conversion Charlse P. Green Suspension - Brakes - Steering 5 01-14-2007 09:09 PM
Rear Disc Brake Pad Replacement ccarccrazy Suspension - Brakes - Steering 3 01-13-2007 07:59 PM
64 el-camino disc brake swap dusterbd Suspension - Brakes - Steering 10 12-16-2006 01:01 PM
3rd Gen disc brake swap Camaro2Fast4u Suspension - Brakes - Steering 1 07-07-2003 05:25 AM
front disc brake wheel cylinder??--bleeders Tom34ford Suspension - Brakes - Steering 2 06-03-2002 04:02 PM
