4 wheel disc master cylinder - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2004, 11:59 PM
qckshftn56's Avatar
I am building a 56 F-100 and need to purchase a new master cylinder. I found a complete kit from CPP for $400 (comes with booster, master cylinder, and proportioning valve for 4 wheel disc). They say it mounts in the stock position, which I assumed was the firewall untill i sa there was no hole there. Also there is a bracket of some sort on the drivers side of the frame around the firewall area. It has two bolt holes and a steel tube sticking sideways out of the front. Is that the bracket for the master cylinder?
Old 05-23-2004, 07:51 PM
302 Z28's Avatar
Sounds like the booster and master cylinder mount below the floor on the frame rail.
Vince
Old 05-23-2004, 10:30 PM
qckshftn56's Avatar
thanks
