4 wheel dr - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2013, 01:07 PM
4 wheel dr
My 4 wheel dr. Stop working and not sure if it is the actuator or the motor on the side of the transmission
Old 10-21-2013, 08:54 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Year, Make , Model, Engine size ?
Old 10-22-2013, 03:45 AM
99 chevy silverado. 5.3L
Old 10-22-2013, 04:10 AM
jokerZ71's Avatar
Wrench Turner
1st & formost,ck all the wiring to & from the actuator,solenoid,etc,& all related fuses.I've only had problems with mine 1 time & the wiring had hung something while mudding & been pulled from the plug.
Old 10-22-2013, 05:17 PM
LATECH's Avatar
Scan it. Chances are It will have a code .Probably a common problem like an encoder motor circuit (switch inside encoder is usually at fault)
It willset a code for that.
I have had them apart a time or two. They are flimsy and lightweight and not much chance of repairing it.
Dorman sells reman encoder motors for about 175.
Fact is stranger than Fiction
Wheel Help! Geradmg Suspension - Brakes - Steering 5 08-19-2008 11:07 AM
hubless wheel: Swiss company re-invents the wheel Jon Hotrodders' Lounge 28 03-13-2007 01:36 PM
recovering a grant challenger wheel and painting the wheel itself gothrod87 Interior 0 09-14-2006 07:02 PM
Are chrome wheel plugs supposed to be loose in Weld wheel? shockers69 Hotrodding Basics 4 03-01-2006 10:05 AM
Wheel well help. HemmiGremmie Body - Exterior 3 07-16-2002 06:09 PM
