Make sure everything is in good working order and you'll be just fine. Not that long ago everything had drum brakes on all four and we stopped all the time. Find a GM power booster and dual master cylinder from a drum brake El Camino or pick up and hook up the lines exactly as they are on the donor vehicle. Disks are great don't get me wrong. But for everyday driving you won't really know the difference.
thanks very much. now do i need to make sure i get a master cylinder for 4 wheel drums? if i get one for front disc is there a proportioning type valve i can use to run the drums?
thanks |
The proportioning valve is only for disk/drum applications. You could use the booster/mc set up from one of those set ups with a residual valve. I know Wilwood makes one for drum brakes, ( $17 Summit) for Street Rods with the booster/Mc mounted low on the frame, I think it will work for your application but I don't know for sure. This valve maintains a small amount of line pressure in the system at all times, when you depress the pedal the mc doesn't have to generate a lot of pressure for the brakes to work and everyone is happy. Otherwise the pedal would have to travel almost all the way to the floor for the brakes to work. Some others on this board know a lot more about this that me and I'm sure they will have more on this set up for you. If not contact Wilwood's web sites tech line. Good Luck
Put a good quality set of brake shoes on it and you will be OK. Drum brakes tend to fade more than discs, after a few stops, so be aware of that.
It's not a sports car, so don't drive it like one..................geesss...I am starting to sound like my old man did about 35 years ago...lol
Ontario Rodders |
