Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4 wheel manual disc questions.
Old 07-04-2012, 12:27 PM
6426yy's Avatar
6426yy 6426yy is offline
Thanks Cobalt,
I'm not into arguing, And I agree with everything your saying. I've been reading up on this since I did the swap. The master I'm using is a 23 or 24mm bore can't remember and I switched to the manual pivot hole on the brake pedal arm. I think it is 1:6 but that's reading someone elses figure not mine. I know all the bleeders are up and I bleed and bleed these to no avail. I used a mityvac like 3 times and then had my stepson help me do it the old fashioned way and there were still soft and wouldn't get harder if you pumped them up. So the res valves I'm using won't actually hurt anything will they? This is mainly a toy and I hope to run it 1/8mi a lil bit.
