4 wire chevy alternator??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2005, 08:36 PM
I've just installed a fuel injected V-8 (from a 1987 formula Firebird) into my 72' Datsun 240z. There are 3 wires(brn,tan/wht and a larger red) coming out of the modular plug of the new alternator along with the battery lug on the back of it. Help!.....what the heck do I do with the plug wires and where do they go?
Old 08-28-2005, 05:28 PM
New Member
Later alternator...
Best get a wiring diagram for the donor car. The later alternators had a separate circuit to power up the fuel pump in the gas tank via the alternator. This was done so that in an accident the motor hopefully stopped and then the fuel pump woudn't spray gas all over the accident!
The pump gets temporarily powered by the key in CRANK position when you start the motor, then the alternator takes over.
Tom
Old 08-28-2005, 06:25 PM
rrmccabe's Avatar
GM Muscle
Dont worry about wiring the alternator.
Thats not enough motor for that car !
Old 08-30-2005, 01:19 AM
docvette's Avatar
Wiki Edits: 12
Doc Here
You...uhhh..wanna rethink that one?
325 HP where 110 HP came out...humm..I think it'll beat the ,muni busses off the line....
DOc
Old 08-30-2005, 06:42 AM
cboy's Avatar
Last journal entry: Finished
Datsun Al,
If you don't have a wiring diagram for your Firebird, you can probably find one here: http://www.autozone.com/servlet/UiBr...ginRepairGuide
Just punch in the year then follow the screens to your make/model - and once you get the the correct repair guide, hit the "wiring diagram" link. They aren't the most complete diagrams available...but I'm sure it will show the color codes coming off your alt. and where they should be wired up.
Dewey
Always learning...and sharing what I've learned.
Old 08-30-2005, 07:02 AM
rrmccabe's Avatar
GM Muscle
haha Doc, I was kiddin.
Cboy, thanks for that link. Did not know that was there.
Rich
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
the brown wire comin from the white clip on a chevy blazer altenator?? badk5 Engine 12 06-27-2005 08:23 PM
65 Chevy Impala Alternator EazyDuzIt102 Electrical 4 04-05-2005 07:30 PM
chevy alternator overcharging at higher rpm tim2 Electrical 3 11-02-2003 10:28 AM
Wire Load On A Newer Chevy Kermit Electrical 2 05-24-2002 08:15 AM
