40 Chevy pick up onS-10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-09-2005, 05:28 PM
fm50ford's Avatar
Hi
I am trying to put my 40 Chevy 1/2 T pick up on an 89 S-10 4x4 frame. Want to use the original V-6 with 5 speed and 4x4.
Has anyone done this?
I am having a problem trying to get the front fenders centered over the wheels. Front area is right into the pulleys. I figure I will have to move the motor and trans/transfer case back about 6-8- inches. This will create a problem with the rear trans mount cross member and the Torsion bar mount cross member.
They will have to be modified.
Any help is greatly appreciated.
Thanks
Fred
Old 01-09-2005, 05:53 PM
poncho62's Avatar
Wiki Edits: 5
welcome....I am moving this post to the General hotrodding forum. You will get better responses there.
Ontario Rodders
Old 01-09-2005, 08:52 PM
advanced design's Avatar
Remember, this is to be fun!
Last journal entry: Lead Joint replacement
While this is not a 40 Chevy truck the S10 frame usage might give you some ideas.
http://www.commerce.usask.ca/staff/h...frameswap.html
Old 01-10-2005, 10:59 AM
Stinkin_V8's Avatar
Suburbanite Member
AD, thanks for linking my site. Always better when someone else does it, I don't like blowing my own horn. There sure is a lot of S-10 swap interest lately, huh?
I've seen this swap done a few times. At the local big car show a few years ago, there was a buildup done over the weekend - they installed a prewar pickup onto the S-10 chassis. The thing was all built previously, looked like they took it apart to paint it and reassembled at the show. It was cool to see but it was a 2WD chassis without the torsion bar suspension. And I remember that they solid-mounted the body to the chassis.
Another one I saw had the steering box sticking out of a hole in the front fender. Looked like it was an 'oops' not expected until the last minute and it just barely didn't clear the fender so they cut a hole for it.
There was another guy I was in contact with that did this swap - '90 S-10 4WD chassis, '38 Chevy. He mentioned he needed another 4.5" in order to fit the rad in. I think he wound up putting the rad behind the cab and apparently it worked great. He mounted the cab up a little higher than most so I don't know if he had steering box clearance problems.
Seems to me that there isn't 4.5" to move the engine back without modifying the torsion bar mount. I need to move mine 4" at some point and it'll be tight with that. But as long as the modifications to the torsion bar mount are solid, it should be easy enough. Moving the trans mount should be straight forward (or straight backwards in this case ), I'm pretty sure there's room to slide it back enough before running into the torsion bar mount. Here's the best pic I could find of that area:
Hope this helps.
Old 01-10-2005, 11:54 AM
bullheimer's Avatar
NEVER use credit cards!
i know for certain tons of guys are doing this swap with two wheel drive, but you are the first i've seen to do 4x4. with stock s-10 components. i have a 40 i was gonna make it 4x4 too but by using the stock frame. good luck, hope to watch your progress
