'40 FORD brakes-how to adjust? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2012, 02:55 PM
Greetings......I have a 1930 Model A Ford Hot Rod with Lincoln brakes on the front and '40 Ford brakes on the rear. The rear brakes seem to dragging and no one in my local club knows how to properly adjust them. Please HELP!...Andy
Old 09-16-2012, 04:50 PM
Wiki Edits: 27
big nuts.
On the bottom of the backing plate there are 2 large lock nuts on the adjusters, you adjust them out to stop wheel rotation then back a bit each one seperately. that said you now have 2 seperate designed systems. the fronts are self energiging and the rear depend on hyd pressure, If you plot the curve for foot pedal pressure and stopping for the fronts and backs, they are different, Might give you scarry braking in a panic stop , Some Chevy Wagons in the 70's or 80's, and some other GM cars use self adjustin, self energizing brakes than can be adapted to your rears and you can convert the fronts to self energizing, There is a lot more info on the HAMB forums, part no's ,etc, most of the Info here is muscle cars, Chevy power train.
Ford 8 Inch which drum brakes? (41 ford) nba1341 Suspension - Brakes - Steering 3 04-27-2012 08:11 AM
how to adjust rear brakes on ranger 2005 buick66 Suspension - Brakes - Steering 1 02-07-2012 02:26 PM
36 ford doors adjust stuckin50s Body - Exterior 5 06-23-2009 08:21 AM
One more time, 40 Ford brake adjust?? CamSweet Suspension - Brakes - Steering 2 04-08-2007 11:33 AM
Ford PU brakes adron s. Suspension - Brakes - Steering 5 04-01-2006 09:58 AM
