40 Ford Coupe door adjustments - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2007, 04:17 PM
At this time, both doors have very little gap at the top rear edge. The hinges are welded to the doors, but bolted to the cowl. What is the best way to adjust the doors so the gap is the same all the way around the door?
Old 12-27-2007, 04:29 PM
If the gap on the sides of the door front and back are good, shim the body mounts that are closest in line with the rear door jambs up. If the gap on the doors looks like the door needs to be rotated in the jamb, you can bend the hinge, in your case towards the front of the car, or the top hinge back, depending where the gap needs to move. If you bend the hinge, make sure the bend is parallel with the line of the hinge pin. Just working on the same thing on a chopped 41 ford pickup, I have had to build up the door edge slightly with weld in some places, you may have to remove some, but don't be too quick with this as if it hasn't been chopped you should be able to get it to fit with shimming body mounts and working with the hinges.
Old 12-27-2007, 05:13 PM
Thanks for the information. I'll work on it this weekend.
Old 12-27-2007, 06:37 PM
old ford guy's Avatar
40 Ford Cpe Door Adjustments
If the upper part of the door is tight to the roof , either shim the body bolts along the door striker side, there should be two points , one at the door edge and the other in front of the wheel well or, the upper hinge can be loosened and washers inserted between the hinge and the body, this in effect tilts the door down at the top. The proper way to determine which way to shim, is to look at the gap along the door edge when the door is closed.If the gap is the same top to bottom, shim under the body to frame, if the gap is wider at the top shim at the hinge.
Old 12-28-2007, 06:11 PM
tip
Thanks for the help. I'll try it this weekend.
41 ford coupe fabricator Hotrodding Basics 13 04-05-2015 08:32 AM
Head liner Bows for a 40 ford coupe brian40 Introduce Yourself 5 05-14-2010 09:37 PM
40 Ford Coupe Dirtbillr Interior 1 02-02-2007 11:34 AM
Need help with Electronic steering for my '40 Ford coupe MichaelSporong Suspension - Brakes - Steering 3 10-27-2006 01:34 PM
Unbelievable 40 Ford, All Steel trees Hotrodders' Lounge 12 09-20-2006 06:39 PM
