40 Ford door lock; screw broken off, remove housing? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-13-2011, 11:55 AM
I see what appears to be a screw with the head broken off looking thru the round hole in the passenger door frame. Worse yet, looks like a drill bit is broken off in the center of the screw. I'm guessing the round housing which holds the lock cylinder was factory welded to the door? Door is finish painted and I wish I could take that round housing out and work on it without stressing the door.
Is this accurate?
Old 10-13-2011, 02:59 PM
I have no answers for you, but it sure brings back memories. I had one of those that the screw wouldn't come out. Did the old heating with a torch and cooling it trick. Yep, I am not kidding, thru that little hole I stuck the torch tip in there and quickly heated that little set screw and cooled it. The screw unscrewed right out.
I don't remember a thing about it as far as what to tell you to do at this point, sorry.
Old 10-13-2011, 06:25 PM
As I suspected everything is welded to the door sooo, I got the broken drill bit out, drilled it, ground down an old tap and fortunately got the old set screw out.
A good day
Old 10-13-2011, 10:44 PM
A good day
VERY cool, you are the man! Talk about having the planets aligned (that and a bunch of skill).
Why only one door lock on a Ford F-100? Z-Money Pit Hotrodding Basics 38 12-30-2011 05:44 PM
40 Ford P/U drivers door lock Alan155 Body - Exterior 2 10-21-2007 05:34 PM
Broken Screw Cesar Ruvalcaba Engine 12 07-13-2007 09:05 PM
Broken Screw Cesar Ruvalcaba Engine 2 05-31-2007 01:17 PM
Broken Tap Remove crossfire84 Engine 7 07-21-2003 05:15 PM
