-   -   40 Ford Front Suspension (http://www.hotrodders.com/forum/40-ford-front-suspension-11644.html)
jsmcoating 10-31-2001 07:33 PM
Does anyone know of a published article giving detailed information for splitting of the wishbones using a new X member kit.
RAW 07-19-2002 07:30 PM
You probably solved this problem by now, but I would bet if you called Chassis Engineering in West Branch(?), Iowa, they would send you the instructions how to split the original wishbones. I did it years ago to install a small block Chevy in a '40 Ford.
jsmcoating 07-20-2002 07:25 AM
your reply is late. However, I did use all Chassis Engineering components for front and rear suspension. It all worked with very little trouble.
