'40 Ford Pickup cab mounts - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-30-2003, 09:40 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Question '40 Ford Pickup cab mounts
Anyone have a picture of the cab mounts on one of these pickups. I have a set of mounts made out of hardwood that came with this truck, along with about two hundred boxes of parts. I'm trying to establish the cab height over the frame in relation to the front fenders, hood, and rear box height.
A fellow told me that Ford used a wood mount in that year, must of shook the hell out of that poor truck. Would prefer to use a rubber mount of the correct height,
Anyone working on this type of truck? Thanks
Old 12-31-2003, 12:27 AM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
the wood is correct for that truck, but may also have a thin strip of rubber under it
Old 01-01-2004, 07:56 PM
Wiki Edits: 647
Were the box mounts hardwood or rubber? Any idea on height?
Old 01-01-2004, 10:55 PM
Wiki Edits: 5
they all where wood & on my 47 ford p/u (same cab) i believe they were 2 inches thick and if there is rubber it would go too the frame
Old 01-02-2004, 03:57 PM
cab mounts wood with long bolt and a sring about 2in long between frame andnut and washer just finished a 47 which is same cab. my n had never been apart so corect. cliff
Old 04-03-2004, 07:41 AM
Wiki Edits: 647
Thanks for the info Cliff. I finally settled the cab on to the frame at a height that I can live with. Put a set of original wood mounts in with a rubber donut on top to absorb some vibration. I think they will work slick. Thanks for the input.
Name:	cab mounts before shims.jpg
