Does anybody know of a good junkyard swap for a 40 ford coupe. We have tried a rearend out of a 68 mustang but it seems too wide.
info I have 66-77 bronco,maverick maybe alittle narrower
A stock 40 Ford rear axle is 60 inches ......measured from the wheel mounting location to the wheel mounting location. ![]() Most people around here try to use a 57-59 Ford rear end from a passenger car. It is 57+" ...measured the same way. They are the narrowest stock 9" Ford I know of. Fairly common and easy to find here in the Southland. I have a 9 inch Ford narrowed to 56" for my 40. That is the lenght TCI uses in their Stage III frames for 40 Fords. Chassis Engineering sells a bolt-in kit with leaf springs, hangers, shocks and everything you need to install a rear end in a 40 for around $450. You can install without removing the body. Only need simple tools and a drill. Go here:http://www.chassisengineeringinc.com/ These sites have 9 inch Ford widths listed hiqties.hypermart.net/9inch.html <a href="http://www.dfwmotorsport.com/Fairlane/9inchrearends.htm]http://www.dfwmotorsport.com/Fairlane/9inchrearends.htm[/URL] You may have rims with too much offset.....to the outside... Hope this helps..... . [ May 14, 2003: Message edited by: Deuce Roadster ]</p>
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
Deuce Rodster, What size are the rear wheels on your 40' and what is the offset? Nice car, my Uncle wants to use the same wheels and wide whites
[quote]Originally posted by 49burb:
<strong>Deuce Rodster, What size are the rear wheels on your 40' and what is the offset? Nice car, my Uncle wants to use the same wheels and wide whites</strong><hr></blockquote> My 40 has 15X7 rims with 235/75/15 tires. The wheels have 4.5 inches backspacing. The rear end is stock (60 inches wide). I have another frame already built to put under it but have not. I have had it 3 years. TCI Stage III roller. It has IFS, SBC, 700R4, and a 9 inch rear. Having too much fun to tear the old 40 apart and redo it..
I used an 8" in 5lug out of a Maverick, no narrowing, move the mount pads in about 1/2 in. if I remeber right. I have a 36 Ford coupe, used 15s x7, 235 70 tires, it looks great. the 8inch is a tough rearend, unless you're going racing it should be p;enty tough. I'll have 350 horses bolted in butI'm not planning on doing more than a scratch ever now and then
Dan[ May 20, 2003: Message edited by: dinger ]</p>
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain |
