40 ford steering column - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2007, 01:38 PM
getting ready to pu column in my 40 ford coupe, what column would fit best
Old 05-28-2007, 12:20 AM
WELCOME to Hotrodders.com
As a former 40 Ford owner ( a standard business coupe ) I suggest a Chevy Van tilt column IF you have a automatic transmission.
I prefer them because they have the shifter on the column, have a neutral start switch mounted to the column and have NO ugly KEY hanging on the side.
I have one in my 32 Ford. They also have the P-R-N-D-L2-L1 on the mast ...
Deuce ... Moderator
Old 05-28-2007, 07:44 AM
60tbirdrick's Avatar
Sacred Steel
Last journal entry: The dash
Deuce,
What year(s) chevy vans are these columns out of? I would like to pick one up myself.
Old 05-28-2007, 08:00 AM
I believe they started with them in 1970 ( GMC vans are the same as the Chevy in this aspect ) ... All those vans look about alike so I am not positive about the year. In about 1981, they went to a larger, less attractive van column ... with all the stuff ( key, windshield wiper control ect ) on them.
They are on eBay all the time ( hint ... hint )
http://cgi.ebay.com/ebaymotors/68-72...em280119452152
http://cgi.ebay.com/ebaymotors/Chevy...em190112537937
And no, they are not my auctions nor do I know the seller.
As a side note, some of the early columns do not have the neutral start switch mounted on them ( like the one in the photo does ). Those vans have a neutral start switch on the transmission. That is the kind of neutral start switch I have in my 32 Roadster ... because in a roadster you can see the column shaft all the way to the floor very easily
Splined steering shaft for 40 Ford column heyjude076 Suspension - Brakes - Steering 2 12-01-2006 12:31 PM
30's Ford steering column bearing? Kruzin Karl Suspension - Brakes - Steering 2 11-27-2006 03:39 PM
steering column for 34 ford coupe jaxhome Suspension - Brakes - Steering 2 09-12-2005 07:59 PM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-04-2003 12:20 AM
best steering column for 29 Ford street rod pikalpha Suspension - Brakes - Steering 5 11-28-2001 11:54 AM
