Hotrodders Bulletin Board > Tech Help> Suspension - Brakes - Steering
Register now (free) or login to remove ads
Thread Tools Search this Thread share on Facebook
  #1
Old 03-03-2003, 10:37 AM
Randy Owens Randy Owens is offline
New Member
Post 40 Ford wheel size-help please
Need help on width of wheels and tire size to use for big and littles on 40 Ford, will narrow rear end to fit.
What wheel width/backspace and size tire would you recomend for front and rear. I plan on new steel wheels/stock hub caps/etc for the oldie look.
  #2
Old 03-03-2003, 10:49 AM
RAW's Avatar
RAW RAW is offline
It is now Saturday, everyday!!
Last journal entry: Project '57 Ranchero
Post
On my '40 coupe with a 4" dropped I-beam front axle and Ford 8" rearend, I'm running:
Front: P185/70 SR14
Rear: P235/70 SR15
btw, the rearend is an original width Ford Granada on Chassis Engineering parallel leaf spring setup.
Good luck, r
[ March 03, 2003: Message edited by: RAW ]</p>
Old 03-03-2003, 06:41 PM
Deuce Deuce is offline
Last journal entry: 32 3W
Post
I also have a 4" dropped axle and the stock rear end.
165X80X15R on the front (stock 56 F100 rim)
235X75X15R on the rear ..7" rim with 3.5 to the curb and 4.5 backspace
I am like the FAT girl at the prom ...
I am just GLAD to be here !!
Old 03-06-2003, 08:41 AM
pasadenahotrod pasadenahotrod is offline
Post
That Std. Coupe is a beauty, too. I used 47-48 Merc 15" wheels on my 40 205-75R-15 on the front and 215-75R-15 on the rear. Used 42 Hubcaps and 40 trim rings. Looked good!
I believe the Mustang (65-68), Maverick(all years), don't forget the Maverick looking Merc Comet, and the Granada (Merc version called Zephyr) rears are all the same. Fit well, don't require shortening.
Back to top
Search this Thread:
Advanced Search
vB code is On
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
