40 Merc steering noise (weird) - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-01-2006, 06:37 PM
Da Hellion's Avatar
I have been building show and race cars for over 30 years and retired but I got talked into one more and this thing is driving me crazy . The car is a 1940 Merc. It has a small block Chev ,Mustang II rack and pin with a stock coll em . Ok hears the problem when you turn the steering wheel about a 1/4 turn it makes a weird noise . It's not a power steering wind noise it's more of a hissing noise . With the steering wheel stopped engine running it still makes that noise .It's like it's coming from the rack and the steering coll em is carrying it into the car. The power steering works great and no leaks and the noise isen't that loud but annoying . it has 2 universals on the feed shaft both under 30 degrees with a dampener new pump and lines. I did rebuild the coll em with new bushings that where in very bad shape but knew this was not going to solve this because it will do it with the wheel turned and holding it still. The Mustang rac and pin where in it when I started working on it so I don't know how new it is
Old 01-01-2006, 08:50 PM
Last journal entry: frame build
You didn't say anything about doing a pressure check, but I would look at the pressure relief valve. Use a long screwdriver or a mechanics stethoscope to listen to the pump, lines and rack while it is making noise to track it down. You'll probably hear it throughout the system ,but the loudest point is the source of the noise. Be careful of hot and moving parts while doing this. You can forget about the column, it's not there.
check er out
Old 01-01-2006, 10:54 PM
Da Hellion's Avatar
colum
Well it's a chev pump with a ford rac so I did have to shim the valve to lower the presser. I got it within specs and even played with different shims to see if it would make a difference but no change. I know the noise is not in the column it's just transferring the noise all the way up to the steering wheel . The u joints are around 25/28 degrees and new they shouldn't bind but that is really what it feels like . The exhaust manifold is almost dead center in the way of the shaft. It's a 2 joint shaft and I am wondering if I should make a 3 joint shaft but that means attaching it to the frame and I would hate to put that much work in it unless I know for sure thats it.Also I did lessen to it with a stethoscope while it was running and when it starts making that noise it just seams to be the same allover and the lines arn't bent or kinked in anyway which would explain why I'm pulling my hair out on this one LOL
Last edited by Da Hellion; 01-01-2006 at 11:02 PM. Reason: I spell like a 5 year old
Old 01-01-2006, 11:03 PM
There are a couple transfer lines on the front of the rack to move fluid from one side to the other. See if one of them has been bent or kinked so it's nearly flat. It sounds like this may be your problem.
Old 01-02-2006, 01:34 AM
Da Hellion's Avatar
You know that's worth looking into because one of them is bent a little .It's not bad but I'll double check that . I am not a power steering expert but I didn't think that could cause this problem. BTW I want to thank all of you for your replies all good so far. And since we are on this subject I have a 72 Ford falcon GT that was in storage for over 7 years .I just picked it up and got it running and the power steering on it makes a whining noise like it's out of fluid but it's full .Heres the catch you can drive it for about 5 miles and its fine then it starts making the noise. It's not leaking which surprises me for sitting that long. I feel like I'm in the Ford power steering Twilight zone
Old 01-02-2006, 03:35 AM
Change the fluid in that Falcon, sounds like it is contaminated with water.
Old 01-02-2006, 10:41 AM
Did you try it with the link disconnected? Might be such a thing as you are amplifying a lesser sound through the steering shaft. I don't think so but worth a look. A hiss would indicate a restricted fluid flow. As you worked on the relief, I would start there. Look for a scratch on the poppet or some grit or dirt under it. Try resetting the pressure to GM spec and see if it goes away. Check lines for a restriction or interior separations. A sharp edge on a flare can cause a whistle, but I have only ran across this in high volume, high pressure hydraulics. Go back and listen again. As I said it will seem to be everywhere, but the loudest source is it. A systematic elimination of possibilities will eventually solve it.
weird power steering gothrod87 Suspension - Brakes - Steering 3 06-15-2005 09:42 AM
steering noise question adrock430 Suspension - Brakes - Steering 4 05-15-2005 07:35 AM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-04-2003 12:20 AM
Why not 40 Ford stock steering box? Randy Owens Suspension - Brakes - Steering 8 01-19-2003 03:59 PM
IFS & retain oringinal '40 Ford Steering column RAW Suspension - Brakes - Steering 8 07-24-2002 08:41 PM
