40 Olds rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-06-2005, 09:10 PM
nomaddaddy's Avatar
Nomaddaddy
40 Olds rear end
I know I probably should change the housing and complete rear end assembly, but has anyone had any luck in changing or finding different ratio gears for this stock rear end??
The rear end is a coil spring setup and to change the assembly would require alot of welding. Also the way things are set up with the panhard rod, there isn't enoung room to run my dual exhaust out the back so they dump out from under the running boards
It is eather a 4:11 or 4:40 ratio now and I would like to go to 3:08 ratio
Thanks!!
Old 07-14-2005, 06:21 AM
FEDDO's Avatar
olds rear
Try a 49/51 olds I think. I used a early olds r/e in a 50 olds. 4.30 best i remember.
Rear end swap required & I'm cunfussed datsun dale Transmission - Rearend 8 12-17-2008 09:03 AM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 03:28 AM
Rear End. Skunk Engine 1 11-05-2004 04:47 PM
Chevy rear end swap Truplayainfla Introduce Yourself 1 10-23-2004 11:07 PM
1975 8.5 rear end camino_man Transmission - Rearend 6 09-18-2004 05:32 AM
