40 plymouth - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2009, 11:50 AM
40 plymouth
i am working on a stock 40 Plymouth and am having a lot of trouble finding brakes parts for it i need to find a place to find them. i have been to lots of parts house and they cant find anything.
thanks rod-99
Old 04-25-2009, 12:31 PM
Stef
Last journal entry: Multi
Hi,
I have restored the brakes on my -48 Dodge witch is similar to Plymouth.
Some of the brake parts are "standard" -like main and wheel-cylinder "inside-gasket" (i don't no the right word) and was found here in Sweden!!
Other hard to find parts I found at Ebay also other parts were found there.
Good Luck
Old 04-26-2009, 01:43 AM
39Hemi's Avatar
Andy Bernbaum should have any brake parts that you need
http://www.oldmoparts.com/
Old 04-26-2009, 10:58 AM
powerrodsmike's Avatar
Wiki Edits: 161
If 39Hemi's source doesn't pan out, or you just want to compare prices, you could try Ply-do, I know they do brake conversions for old plymouths, but alot of times those guys have good sources for the stock stuff.
Ply-Do
RT. 1. Box 277B
Delbarton,
Phone: (304) 475-3245
More companies specializing in obsolete Chrysler brake parts.
Atlas Obsolete Chrysler Parts
10621 Bloomfield St
Los Alamitos, CA 90720
562-594-5560
Moose Motors Obsolete Brake Parts
(707) 792-9985
Petaluma Ca
Later, mikey
BE different....ACT normal.
Old 04-26-2009, 02:22 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
You don't say in particular what you can't find. Are you looking for shoes, cylinders, hoses? In most cases you can go back to your jobber with your old shoes and have him send them back to the remanufacturer for new shoes (linings) to be installed on your cores. Kits are available to repair your wheel cylinders. Hoses can be compared and fitted to those a jobber has in stock, plus or minus an inch or a bend.
Try using someone other then a "chain" auto parts store, a good independent will help you out over the long run.
40 Plymouth P10 Sedan Steering Column Swap Sleezie Suspension - Brakes - Steering 4 02-09-2015 03:57 PM
40 plymouth..new member laxdad944 Introduce Yourself 1 03-25-2006 11:16 AM
40 plymouth steering pmiller666 Suspension - Brakes - Steering 1 01-13-2006 06:26 AM
40 Plymouth front end John W. Martin Suspension - Brakes - Steering 7 10-28-2003 10:38 PM
40 plymouth HELP!!! dave5113 Suspension - Brakes - Steering 5 02-13-2002 08:55 AM
