40 Plymouth Buisness Coupe Frame help - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2010, 08:53 AM
happydad's Avatar
Hello All
I have a 40 Buisness Coupe that is sitting on a butchered frame..The P/0 actually took a diplomat frt and cut the frt offthe orig frame and welded the two on top of each other.!!! So I need ideas on what kind of full frame auto would fit the bill..Or should I try and correct the madness..Cut apart butt weld togeather and box the repair
Thanks for the help
Old 05-03-2010, 06:02 PM
48ChryslerRodder's Avatar
Stuck in the past.
You won't find a frame that will be an easy swap. It can be done though. Some have done it using S-10 frames. I have also heard of the front frame clip from a Volare being used. I would say that you may be better off repairing what you have. I suggest posting some picture of the frame where it is joined and you can get advice from more of the members.
Old 05-03-2010, 06:14 PM
happydad's Avatar
Thanks for the reply...Yes I will post some pics
Old 05-03-2010, 07:25 PM
Wiki Edits: 31
diplomat front stub has been used in hotrods, so it might just pay to fix what you have
1937 Plymouth Coupe Frame bigobambam Hotrodding Basics 2 09-17-2009 01:27 PM
48 plymouth to s-10 frame ParatrooperAlex General Rodding Tech 5 11-09-2007 12:46 PM
40 plymouth..new member laxdad944 Introduce Yourself 1 03-25-2006 11:16 AM
37 chev coupe 40 pontiac coupe duke mauk Introduce Yourself 2 01-25-2006 12:50 PM
1939 Plymouth 5 window coupe conversion 39Plymouth Introduce Yourself 3 12-30-2005 07:55 PM
