-   -   40 plymouth HELP!!! (http://www.hotrodders.com/forum/40-plymouth-help-11870.html)
dave5113 02-05-2002 08:47 PM
40 plymouth HELP!!!
I have a 1940 Plymouth P-10, 4 door,a 1968 auto and 327 out of a vett. I cut the frame on a truck and added 24" to it, put 100,000 miles on it with no trouble. Never did a front end.I would like to use a clip out of a car or truck, but I want it to be safe.Could some one tell me what would fit? What rear end would fit with leaf springs?? THANKS for any help you could give me.
Roy Newton- exprotech 02-11-2002 09:57 PM
What do you need to know first big guy lets get this puppy going. ROY
dave5113 02-12-2002 04:23 PM
Do you know what GM car I could get to use the front end that has IFS? I would like to get the whole car to use other parts, like AC. THANKS
Lash 02-12-2002 06:21 PM
[quote]Originally posted by dave5113:
<strong>I have a 1940 Plymouth P-10, 4 door,a 1968 auto and 327 out of a vett. I cut the frame on a truck and added 24" to it, put 100,000 miles on it with no trouble. Never did a front end.I would like to use a clip out of a car or truck, but I want it to be safe.Could some one tell me what would fit? What rear end would fit with leaf springs?? THANKS for any help you could give me.</strong><hr></blockquote>
Lash 02-12-2002 06:28 PM
I'm a little confused.Is your frame stock or is that truck frame under it?If it is stock a70's Charger or Challenger 8 3/4 rear willbolt right in.I have a 41 (same frame)with a 71 Charger rear..Lash
dave5113 02-13-2002 08:55 AM
The frame is stock.Charger or Challenger would be imposable to find up here. Did you change your front end? If so, what did you use? Thanks
