$40 TCP Global "pro" gun OK for spraying thick primer surfacer?
Has anyone here used the "pro" guns from this company on ebay? I'm thinking about getting a 2.0 tipped gun for when I spray the thick primer surfacer. The ad says I can get bigger/smaller tips/caps for the gun. Price is about $40. I'm not looking for a gun that has to last years and many cars worth of shooting. My panel truck is the only vehicle I'm trying to do. I do understand and have seen the difference in quality tools, but I can't see spending hundreds of dollars on a gun I'll use on one or two jobs. Would a H.Freight gun be as good or better? I've been looking on Craigslist for a used quality gun, but not much luck.....
thanks for the time |
Thanks Count.
I've never ordered anything from TCP Global, but they have good reviews....Is the 2.0 tip big enough to spray Evercoat's Slick Sand? |
Since I have never used Slick Sand. I don't know. I have a philosophy of "Keep it Simple". That way less mistakes are made and a better product produced. We don't take short cuts but stick to tried and true methods.
I've heard good things about Slick Sand, but... I prefer products to been on the market for awhile and see how they hold up with time. Too many NEW items pop up and then a couple of years later problems start appearing. So, KISS "keep it simple stupid" is my motto. Frank Cox Cox Custom Cars |
Did you try going to their forum and looking for an answer there from people who have used them? try http://www.paintersforum.com/
evercoat has been developing polyester products longer than most of the cheap stuff out there. stay away from cheap primers and second line stuff.
the vaper 2.3 is a good gun for poly and can be bought from northern for 44.00. |
Thanks for the replies. I finally had the brain storm
of going to look at the Slick Sand tech sheet; it says 2.0 or larger. I think there is a Northern in Tampa, so I will check out their gun you mentioned SHINE; that is definitely in my price range for a gun I'll use one or two time Thanks again, James |
now i'm not a fan of cutting corners or cheap stuff when it comes to a hotrod. but i bought one of these guns to shoot epoxy with. not going to get into a pissing match on epoxy only, just an example. after getting the gun set i can get single coat mill equal to a double coat with a 1.4 . double coat with the 2.3 and i've got enough to block without sandwiching peel or anything else each coat. it's a cheap gun, keep it clean and remember the seals on the cap are a little weak. don't gorilla it .
i think roger1 got one of them to try. |
I'll post back here with my experience with it after I try it out. Btw, shine, I used my new Iwata LPH400 for the base and clear on the firewall. I like it! I'm putting the body back on the frame right now. I used that furniture wrapping stretch cellophane around the frame. Worked pretty darn good. |
dont laugh roger but in my younger days we actually wrapped frames and stuff with aluminum foil. if forced into it i would use spray mask. it washes off with soap and water. used it for race cars. something about paint first they don't seem to get.
I bought one of those 2.3 Vaper guns from Northern to shoot some S-W high build industrial epoxy primer. Worked like a champ. My dad later used it for some feather fill he was using on a pickup. He had a 2.0 primer gun already, but said the 2.3 worked a lot better in getting that primer to flow out without excessive thinning.
| Maaco vs. At-Home Paint Job | nightrain_rod | Body - Exterior | 127 | 08-26-2012 03:07 AM |
| "Basic of Basics" How do I paint my car myself? | Centerline | Body - Exterior | 5 | 11-07-2011 07:14 AM |
| Martin Senour Tech Sheets? | unstable | Body - Exterior | 42 | 03-12-2011 09:09 PM |
| "Basic of Basics" Welding - How do I repair body panels? | Centerline | Body - Exterior | 29 | 06-18-2009 06:54 AM |
| More on Orange Peel | KarKen | Body - Exterior | 36 | 03-22-2009 02:18 PM |
