-   -   400 +.030 SBC estimated hp/tq. (http://www.hotrodders.com/forum/400-030-sbc-estimated-hp-tq-227967.html)
mschiffel@comcast.ne 01-04-2013 08:00 PM
:welcome:...I have a 400 Chevy small block installed in the engine room of a 1948 Chrysler New Yorker...it has a TH350 with a stock converter behind it...I haven't run the engine yet because I still have to do a few things like install the Griffin aluminum radiator and the ignition wires...when I get it started the cam will have to be broken in first...my question is this...how much horsepower and ft./lb. of torque will this engine make?...here's a rundown of what I have...the engine is a professionally remanufactured unit with a .030" overbore and stock type pistons...the camshaft I specified when talking to the rebuilder is a low-mid range stump puller torquer....the heads have stock 1.94" intakes and stock exhaust valves...all new....new pushrods and rockers and lifters complete the package...the compression ratio is stock...I'm guessing 8.5:1....I'm using the ram's horn cast iron exhaust manifolds...the intake is an Edelbrock Performer, topped with an adapter and a Holley 500CFM two barrel carb on top...the ignition is a 1963 Chevy 283 points style unit...I have 2" diameter pipes from the ram's horns going into turbo mufflers and 2" tailpipes....so what do you guys think ?...the Chrysler is a 4,000lb. car and it's a cool cruiser....any guess as to hp and torque numbers?
vinniekq2 01-04-2013 08:28 PM
maybe 260 hp and 340 torque.What were you expecting?
mschiffel@comcast.ne 01-05-2013 12:03 PM
The HP sounds right on the money...I was hoping for around 400Ft/Lbs Torque give or take maybe 10Ft/Lbs or so. As long as it makes lots of grunt off idle to 4,000RPMS. Winding it up high is not in the cards. Thanks for your input.
