400 +.030 SBC estimated hp/tq. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-04-2013, 08:00 PM
Mike S.
...I have a 400 Chevy small block installed in the engine room of a 1948 Chrysler New Yorker...it has a TH350 with a stock converter behind it...I haven't run the engine yet because I still have to do a few things like install the Griffin aluminum radiator and the ignition wires...when I get it started the cam will have to be broken in first...my question is this...how much horsepower and ft./lb. of torque will this engine make?...here's a rundown of what I have...the engine is a professionally remanufactured unit with a .030" overbore and stock type pistons...the camshaft I specified when talking to the rebuilder is a low-mid range stump puller torquer....the heads have stock 1.94" intakes and stock exhaust valves...all new....new pushrods and rockers and lifters complete the package...the compression ratio is stock...I'm guessing 8.5:1....I'm using the ram's horn cast iron exhaust manifolds...the intake is an Edelbrock Performer, topped with an adapter and a Holley 500CFM two barrel carb on top...the ignition is a 1963 Chevy 283 points style unit...I have 2" diameter pipes from the ram's horns going into turbo mufflers and 2" tailpipes....so what do you guys think ?...the Chrysler is a 4,000lb. car and it's a cool cruiser....any guess as to hp and torque numbers?
Old 01-04-2013, 08:28 PM
vinniekq2's Avatar
maybe 260 hp and 340 torque.What were you expecting?
Old 01-05-2013, 12:03 PM
Mike S.
The HP sounds right on the money...I was hoping for around 400Ft/Lbs Torque give or take maybe 10Ft/Lbs or so. As long as it makes lots of grunt off idle to 4,000RPMS. Winding it up high is not in the cards. Thanks for your input.
Estimated HP and Torque sbc 355, please AR_Racing_627 Hotrodding Basics 11 08-15-2011 05:05 PM
Sbc 327 (Estimated HP) PaulsChevy64SWB Hotrodding Basics 19 02-23-2011 04:32 PM
Estimated horsepower for this 350 sbc? Hanks56Chevy Engine 4 03-19-2010 04:08 PM
stock 400 SBC crank in a 383 turned .030 on rods flyin99 Engine 2 04-16-2006 03:56 AM
400 bored .030 camaroman70 Engine 56 05-05-2005 05:36 PM
