400 bored .030 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2005, 04:05 PM
400 bored .030
Ok, I've got a 400 sbc bored 0.30 over. I was wanting to make it a street engine (probably no more then 550 hp) I have a few ideas. I was thinking about stroking it and putting either vortec heads or the Edelbrock E-Tec 200. I was also thinking about doing the exact oppisite and putting a 350 crank to make it a 383 and have the revs. It is only going to be a weekend car of course. Which combo would be better? And how much power could I end up with?
Old 04-28-2005, 04:36 PM
jesse01's Avatar
mini me
why must you mention "heads" gees man didn't you learn anything from that last "head" post
I thaught if you put a 350 crank in a 400 block it became a 377
but as for the rest you already said it if you stroke it = more HP, but if you go the other way it's all torque
so it's mainly up to you the Q is which do you want????????
oh de-stroking it if you decide to use the 350 crank in the 400 block you might have to use "spacer bearings" since the 400 is made w/a large 2.65 main journals as for the 350 crank it was made for a 2.45 med. journal
or you could get a custom ground crank$$$$$$$
If it was me I'd go the other way towards stroking it, but it's not
J
Old 04-28-2005, 04:46 PM
Ok well I guess it is a 377. I still need to work on my auto math . So your saying, if I go with a 350 crank i'll get more torque?
Old 04-28-2005, 04:48 PM
jesse01's Avatar
mini me
Yes
Jesse
Old 04-28-2005, 04:52 PM
lluciano77's Avatar
You can get 383 from a destroked 400.
Old 04-28-2005, 04:53 PM
lluciano77's Avatar
Originally Posted by jesse01
Yes
Jesse
You will have less torque and less power initially with the destroked engine.
Old 04-28-2005, 04:54 PM
lluciano77's Avatar
You won't get 550 hp with the E-Tec heads. For those numbers you will need the Victor heads. AFRs will do it too. So will the Motown lites.
Old 04-28-2005, 04:55 PM
jesse01's Avatar
mini me
well i never did it myself my last machinst says he built his that way for the torque not the HP
but if i built my own that way I'd be more sure
oh, and i didn't mean he'll have more than he has right now
J
Old 04-28-2005, 04:59 PM
So is there really any good in destoking an engine if you dont get torque or power?
Old 04-28-2005, 05:01 PM
jesse01's Avatar
mini me
sure if thats to many c.i. for ya
J
Then what would the E-Tecs be good for?
Old 04-28-2005, 05:02 PM
lluciano77's Avatar
Yes. You can get better rod ratios that way. There was a build in Hot Rod magazine called "The 350 Chevy Should Have Built". You can do a search and find it. It uses a 400 block with a 350 crank. It still won't make more power or torque than the 400, but it is way more efficient than a standard 350.
Old 04-28-2005, 05:03 PM
lluciano77's Avatar
Recycling.
They are okay heads, but for the same money you can get heads that flow a lot better.
J
I ain't no *****, I can handle the c.i.
Old 04-28-2005, 05:06 PM
More efficent as far as gas mileage? Well if they are the same amount i'll go with the better heads
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
400 SBC bored into a 427?? BadAss_Beaver Engine 21 10-29-2004 04:46 PM
0.060 over 350 sbc or 0.040 over 400 splayed cap sbc tony350ss Engine 4 05-17-2003 09:02 PM
400 327 crank limey Engine 8 09-24-2002 07:53 AM
Small Block 400 chevyelc81 Engine 9 06-18-2002 06:10 PM
