heres some ideas
Displacement: 408 cu. in., (0.040 in. over 400)
Carburetor: Holley 750 double pumper with a 2 in. Edelbrock spacer
Heads: GM #441, with 2.02/1.60 in. valves, some minor bowl-work, and a 3-angle valve job
Intake: Edelbrock Performer RPM
Camshaft: Lunati Street Master hydraulic, with 285° of duration, 235° of duration @ 0.050 in. lift, and 0.507 in. of lift
Rockers: Lunati
Headers: Hedman 1 3/4 in. headers
Pistons: Lunati forged
Rods: Lunati
Crank: Lunati
Distributor: MSD 6A
Comp. Ratio: 9.5:1
MAX HP: 384 @ 5000
MAX Torque: 448 @ 4000
Heads: Brodix street heads, with 165 cc intake runners and 2.02/1.60 in. valves
Rockers: Lunati
Rods: Lunati
Crank: Lunati
Distributor: MSD 6A
Comp. Ratio: 10.2:1
MAX HP: 397 @ 5000
MAX Torque: 466 @ 4000
Heads: Brodix -8 heads, with 185 cc intake runners, 2.05/1.60 in. valves, and a back-cut on the exhaust valve
Rockers: Lunati
Rods: Lunati
Crank: Lunati
Distributor: MSD 6A
Comp. Ratio: 10.2:1
MAX HP: 410 @ 5000
MAX Torque: 476 @ 4000
Intake: Edelbrock Victor Jr.
Rockers: Lunati
Rods: Lunati
Crank: Lunati
Distributor: MSD 6A
Comp. Ratio: 9.5:1
MAX HP: 393 @ 5000
MAX Torque: 434 @ 4000
Rockers: Lunati
Rods: Lunati
Crank: Lunati
Distributor: MSD 6A
Comp. Ratio: 10.2:1
MAX HP: 401 @ 5000
MAX Torque: 455 @ 4000
Rockers: Lunati
Rods: Lunati
Crank: Lunati
Distributor: MSD 6A
Comp. Ratio: 10.2:1
MAX HP: 417 @ 5000
MAX Torque: 460 @ 4500
Displacement: 406 cu. in.
Induction: Accel EFI
Heads: Edelbrock Victor Jr. CNC
Camshaft: Crane hydraulic roller, with 286/294° of duration, 236/244° of duration @ 0.050 in. of lift, and 0.525/0.579 in. of lift (Corrected valve lift with 1.6:1 rockers is 0.560/0.579 in.)
Rockers: Crane 1.6:1
Headers: Hedman 1 5/8 in.
Pistons: Wiseco forged aluminum
Rods: Trick Flow 6 in.
Crank: Cola
Distributor: Accel
Comp. Ratio: ?
MAX HP: 460 @ 6000
MAX Torque: 450 @ 4000 and 4100
Heads: Air Flow Research 210, with 2.08/1.60 in. valves.
Camshaft: Crane mechanical street roller, with 0.525/0.543 in. of lift and 236°/244° of duration @ 0.050 in. of lift.
Exhaust: Hedman 1 5/8 in. headers with Borla XR-1 mufflers
Pistons: forged
Rods: stock
Crank: GM
Ignition: MSD 6AL
Comp. Ratio: 10:1
MAX HP: 487 @ 5500
MAX Torque: 494 @ 5000
