#1
400 build
i have read several different articles on building a big block 400 , using the 440 crank with either the 400 or 440 rods . Well what about using the 400 crank with the 440 rods . may sound goofy but what the hell everything else has been flip flopped . Will it work or destroy my block. and if it will work , what am i looking at as far as CIs or power numbers using stock components
Register now (free) or login to remove ads |
#2
A 400 crank in what block (bore)? Whatever rod you use won't effect the displacement, you will need different compression height pistons with a shorter/longer rod. The cranks have different strokes, for instance if you used a 400 bore block (4.340) and a 440 crank (3.750 stroke) it will give you 444 c.i., regardless of what rod you use. The are small benefits realized with different length rods if you're squeezing a motor for every ounce of power, that's an ongoing debate which way to go.
''Life's tough, Pilgrim, and it's even tougher if you're stupid.''---John Wayne Midnight Sun Street Rod Association |
#3
| Thread Tools | Search this Thread |
| Similar Threads for: "400 build" | ||||
| 355 build??'s about compression and build | impalaman355 | Engine | 6 | 06-06-2011 10:20 AM |
| 355 build up | chevythmpr | Engine | 14 | 03-13-2010 03:48 PM |
| 383 build | beachbum | Engine | 1 | 03-01-2010 11:38 AM |
| USA BUILD vs CANADIAN BUILD? | troy norrad | Hotrodding Basics | 19 | 02-18-2008 09:57 PM |
| 200-4r experts - build questions - Which core is best to build on? | Warrant | Transmission - Rearend | 7 | 10-09-2007 07:36 PM |
