Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 400 chevy short block with 97 vortec heads?????
Old 08-12-2010, 02:12 PM
Rickracer's Avatar
Rickracer Rickracer is offline
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
Originally Posted by SSedan64
I thought the 97 Vortec engine used Multi Port injection, not TBI?
You are exactly correct sir, I didn't even think about that. The one I was referring to was a 95. 97 would be Multi-port. I know Vortecs work very well with mild bigger cube motors, but with 4 v.r. flat tops, I agree with ericnova72, it would probably have too much compression. Being a 97, (OBDII), you should be able to do your own programming though.
