400 chevy small block - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2012, 07:34 PM
We have an Austin Healey replica with an engine out of a 1972 Chevy Caprice., It looks as though a previous owner installed an Edlebrock Performer intake with a Quadrajet carb. It does not look as though the heads were changed., I am thinking of installing different heads to increase the HP. Should I rebuild the lower end and change the cam at the same time? The car has 25000 miles on it but engine mileage is unknown. From the numb numbers on the block it is a 4bolt main. Any sugestions would be appreciated. Thank you.
Old 08-27-2012, 08:21 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
What numbers on the block tell you it's a 4-Bolt?
If the motor only has 25k on it, it shouldn't need a refresh unless it's been abused and shows signs, smoking, low compression, etc.
Semper Fi
Old 08-30-2012, 12:07 PM
400 Chevy small block
Thanks for the feedback.
ID# is T0913CKP - Tonawanda, September 13, 1972 Caprice
Block casting # 511 = 400 SB 4bolt Main (3 freeze plugs)
duehew
400 Chevy Small Block 69ChevyC10 Engine 5 05-11-2008 04:50 AM
400 small block chevy shevyman Engine 11 01-15-2007 05:52 AM
Small Block Chevy 400 JohnyR17 Engine 7 10-06-2006 10:46 AM
chevy small block 400 jerry1 Engine 4 09-08-2006 07:24 PM
400 small block chevy bo 1972 Engine 1 12-24-2002 07:03 AM
