400 dip stick - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-07-2008, 01:41 PM
400 dip stick
i am wondering if the dip stick on a 400 is the same as a 350 since the crank has a bigger throw would a 350 dip stick let the crank ride in the oil when full?
Old 01-08-2008, 05:25 AM
bondo's Avatar
Ayuh,......
A 5qt. base is a 5qt. base........
It Shouldn't Matter......
Old 01-08-2008, 06:21 AM
Don't really know the answer to your question, but I do know there are several different configurations of SBC dipstick placements, lengths etc. My 383, which I did not build (350 block, 400 crank), has a dipstick that has been calibrated with new etchings for ADD and FULL. We keep a supply of different SBC dipsticks hanging on the wall so we can select the right one when we are mixing and matching SBC components.
Trees
Old 01-08-2008, 04:25 PM
Dipsticks measre from the pan rail DOWN so it doesnt matter what SBC you use... But I will tell you most if not all dipsticks are marked different... If its a stock type motor just get any dipstick... If its a race motor measure the crank throw from the pan rail and mark your dipstick yourself...
Dip stick question Old_97 Hotrodding Basics 3 12-04-2006 05:26 PM
SBC Dip Stick Sleeve Removal Houston54 Engine 4 09-26-2006 06:35 PM
383 or 400?? KFXrider88 Engine 7 06-13-2006 05:45 AM
400 Combinations MI2600 Engine 15 05-12-2006 07:08 PM
Tranny dip stick tube gilby246 Transmission - Rearend 2 05-11-2005 01:07 PM
