400 heads
Ok guys, I read a lot of info on Vortec heads and they sound great. I have an uncle who owns a tow company and sometimes has total losses he can part out so getting a set would not be that hard to get. I have a 1971 400 all stock,heads to match. 511 block and I think 493 heads. I want to end up with a daily driver with a little power and still some fuel economy. because I already have rpm intake for the stock heads I would like to go that way. I think with vortec I would have to buy an intake that will allow a carb. What do you guys think? my friends all say buy a crate engine and sell 400. But me and my boy want to build it together.
The machine shop I talked to said he would go through my heads and rework them for $125.00 each. but If I end up with junk thats not good but on the other hand if I had a lot of money I can buy plenty of other heads Im sure. What would be a good cost effective way?,in your opinion.
ok. my goals are 16mpg and 350 hp or so. I will use almost everyday. It is going in my 1983 elcamino which i drive everyday with a tired 305 in it. I get 15.8 to 16.0 mpg now but it doesnt have too much get up and go. It will spin the tires but they are small tires and I plan to go up a size to 15". I have a 200 trans and I think gear ratio is 2.41..I feel pretty strongly if I put this 400 in I will be pleased with the difference from now but I dont want someone saying you should have asked because for another $100 bucks you could have done this And had plenty more power or gas mileage
9:1 CR,you pick the heads
180235-10 NA 266 270 213 217 .485 .495 110 106 Hyd. Hyd. 1 1000-4800 Fair idle, good low & mid-range performance increase. cam like this or smaller street master intake edelbrock 600 or equal 1 5/8s headers this with the 2.42 gears will work nicely and still make a high 14 second pass. mileage will depend on car/tires/suspension. 16 plus to the U S gallon should be very easy |
( I have a 200 trans and I think gear ratio is 2.41..I feel pretty strongly if I put this)
the 2.41 gear is ok for gas mileage,just dont expect super fast 0-60 times. the cam I posted was just an example of a cam that would rev to 4,800 rpm in a basic 350 in a 400 it would likely start to cap out about 4400 rpm. The low rpm power is good for tall gears and more mileage oriented than a long duration cam. you will need to change the pistons if you rebuild the engine??? decide on what heads you want to use,then calculate the piston size to give you 9:1 compression ratio,,ie,if you use 76 cc heads like the stock 400s came with,then the stock replacement pist will give you around 8-9:1 cr ,depending on what exact pistons that you order. what ever decision you make,you will want around 9:1 cr,small cam,small carb,headers etc |
| The Following User Says Thank You to vinniekq2 For This Useful Post: | ||
gmtony55 (02-20-2013) | ||
Thanks for your reply. this engine ran good when it came out and I was tempted to put it back in without taking pistons out. but it set up a while and I figure I would have it honed and re-ring it but I am planning to keep same pistons. I get the jist of what you are saying and mid 14 second pass would be about what I am shooting for.
Take it apart and check for wear,see what pistons are in the engine.If ite 8:1 then you can upgrade the heads,replace the cam and timing chain,put on a better intake,enjoy the ride.
post pictures and or specs when you get the engine partially apart |
ok. I will do just that.thanks
| 1967 400 with 670 heads. Trying for 400 Hp street | 67pontiac400 | Engine | 23 | 07-20-2012 07:45 AM |
| 400 heads | lost1er | Engine | 3 | 02-15-2009 01:40 AM |
| heads for my 400 | speed_demon666 | Engine | 8 | 10-21-2007 06:56 PM |
| 400 heads | joe350s10 | Engine | 9 | 01-19-2006 07:05 AM |
| heads for 400 | lilbandit3 | Engine | 3 | 08-12-2003 08:47 PM |
