Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 400 heads ideas
Thread: 400 heads ideas
Old 11-21-2012, 03:16 AM
LJM97Z LJM97Z is offline
Originally Posted by smith9300 View Post
Hello im 19 and im pretty new with engine work and i have a stock 400 sbc i have a comp cam xe256 that i bought but i wanted to redo all of the top end and dont really know where to start. I dont have a lot of money but just want to run some stock chevy heads on it. just lookin for ideas on what heads would be good to run on it. Any Feedback would be apperciated
IMO, if the stock heads are in decent shape use them, If you don't have alot of money to work with, don't get caught up in all the "YOU NEED" this & that, A simple stock 400 will have enough torque to keep you happy, I'm talking stock right down to the rotating assemble, That little xe256 you have will work just fine in a stock 400, If you want, just add bolt-ons like a decent set of headers (1.5/8) & Perf. intake, I got caught up in the "your compressions too low", The stock heads are junk, your leaving too much HP on the table Yada Yada Yada......, I'm "somewhat happy" with my 406, its got Iron eagle heads, decent cam, 10.4 compression, 750dp, RPM intake, headers, but i had a stock "re-ringed" 400 in a 78 2wd blazer back about 12 yrs. ago, all it had was headers & RV cam, That Blazer was a blast to drive, loads of torque, & yes, it had the crappy 882 heads & 8.1 compression, that was it, nothing fancy.
