400 horsepower 1/4 mile time - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2012, 12:34 PM
Hi,
Will my 400hp sbc get me in the 12 secs in the 1/4 mile.
My car weighs 2600lbs,T5 manual,3.09 rear gears(small 23" tyres though)
with the camelhumps it did 14 secs,now Im putting procomp 210cc on,or will I need to spray it as well?
Fed up with being beat by 4 cylinder turbo cars!
Thanks in advance
Old 08-02-2012, 12:49 PM
vinniekq2's Avatar
400 crank hp?
If a car that light with that much power doesnt do high 11s dont tell anyone.My 67 camaro had about 380 rwhp and ran high 11s @ 114 weighing 3560 with me in it.
my 80 camaro ran 11.9s @110 weighing 3750 ish with me in it.probably made less HP than the 350 in my 67 but more torque.It was an LS-5 rat with a solid cam and victor oval port,stock LS-5 heads ,no porting,but it had 2.19/1.88 stock valves from my LS-7
Old 08-02-2012, 01:12 PM
Thanks for that! a bit reassuring.
When I ran it with unported camelhumps it would only do 14.50@96mph,it did seem it was holding back on the top end of each gear,if it does 12s or even high 11s with the new 210cc heads does that equate to about a 100 horsepower gain? Can the heads make that much difference? Everything else on the motor is the same!
Old 08-02-2012, 01:23 PM
vinniekq2's Avatar
I ran high 11s with GM angle plug heads.If your heads on the engine are terrible and the new ones are marvelous then 80 to 100 is not too far off.I would think 50 would be more realistic.so many variables? what headers/cam/intake/ carb are you using?
Old 08-02-2012, 01:33 PM
Im using a magnum 280 cam(480/480 lift),rpm intake,650 holley dp,only thing that I can see not good is block hugger headers!(not got much room)
Heads are procomp 210cc,mallory unilite and roller rockers.
When I run the camelhumps I had 600 holley v/s and points dizzy.
Was considering some 1.6 roller rockers to give me a bit more lift,would of taken it to 510/510
One thing worth mentioning when I had the valve guides redone(sleeved) they came back worse than before,only just noticed when I stripped them down the other day,no exaggeration they had +0.030 play in them! Smoked like a train especially on the over run
Old 08-02-2012, 01:38 PM
vinniekq2's Avatar
Im not a big fan of hydraulic flat tappet cams.650 will work for now. I used an 850 on my 67 camaro with a 355. msd type of ignition with a rev limiter is nice.the rev limiter can save the engine if a driveline part ever breaks at WOT
Old 08-02-2012, 01:44 PM
I thought a 850 was too big for a 350! Anyway you ran some good times in your cars,hope I can get near them times,thanks for your advice
I like the idea of a rev limiter
Old 08-02-2012, 02:00 PM
vinniekq2's Avatar
I run a 950 on my 434.Brandon Gueverra,a local fella at mission uses a 4777 holley with 4781 base plates,top is milled and ported venturis,even though it started as a 650,it now flows over 1000 cfm. small solid roller cam 355 runs 10.8s.This car has been around 25 years so its well tuned.On the chasis dyno it made a little over 400 rwhp.Its the entire package that counts.his car is 3100 pounds,using 4.88s and a powerglide.not street driven anymore.
Old 08-02-2012, 02:13 PM
Shall I use my 650dp or my 750v/s carb then,mainly using the car on the strip not going to be a daily driver!
Old 08-02-2012, 02:19 PM
vinniekq2's Avatar
use the carb you have for now.when you want to go faster,borrow a good working 750,then let the owner try and get it back from you.
Old 08-02-2012, 02:27 PM
Nice one,will try that!
1/4 mile time kwopper07 Hotrodding Basics 17 12-10-2007 04:25 AM
quarter mile time 63futura351w Hotrodding Basics 17 06-10-2005 04:31 AM
Does Your Mph In The 1/4 Mile Represent Your Horsepower 70SPORT Engine 18 07-01-2004 09:33 PM
1/4 mile time???????????/ 3dhunt General Rodding Tech 0 08-26-2003 04:15 PM
1/8, 1/4 mile time help Rubberman2003 Hotrodders' Lounge 1 04-16-2003 06:05 PM
