Thread Tools Search this Thread share on Facebook
  #31
Old 02-08-2009, 06:03 PM
ap72 ap72 is offline
How fast is fast enough?
Originally Posted by F-BIRD'88
"it says 416 350 heads, instead of 305"
I'd expect a better critique than that from you, Tom.
The program did not generate those notes on the graph. I did.
They can be if you don't know how to enter the variables.
Like real flow figures, port cross sectional area etc, which I did.
Accuracy: A friend built and dynoed the second combo from the first graph
except with functionally the same (as the 993's) 882 heads and 8.8:1. Made 336HP on the dyno. Simulation predicts 340HP. Thats pretty close.
The graph with the tunnel ram and big Isky cams does predict a bit more than I give it. I'm looking for 440hp from it.
Will find out later in the year when I get it in the car for testing.
I already built a very simular engine combo to this combo, before with a big single plane. Trust me, it makes excellent power.
I'm expecting 12.3 12.4 ish quarter miles out of it, with the tunnel ram in my car. Not too shabby for the few hundred $$$s I got invested in it.
Other people who have run simular 350ci w/ported 416 heads combos, run even faster than this, so......
There's a lot of time and talent involved in doing that, but those are the ones that turn my head. Anyone with a mastercard can throw together a big inch maxed out LS series engine and make 700 hp- that's all because of the amazing technology available off the shelf. But the people that can run 11's on stock 305 castings- well that's something to take notice off. Atleast in my book.
Register now (free) or login to remove ads
Old 02-08-2009, 07:58 PM
machine shop tom machine shop tom is offline
No, really? Gee, I never thought of that................
tom
Old 02-11-2009, 09:35 AM
ssonny34@yahoo.com ssonny34@yahoo.com is offline
400 horsepower
I can remember back along time ago when every engine around had 400 horsepower, supposedly. As I've aged and discovered dyno's and dollars I now know that most are lucky to have 350 let alone 400. horsepower aint cheap. Gotta spend some money. We had a stroked buick that made 550 on a dyno. I had never had one like this before. My buddy said "mine makes the same" I had rode in his quite often so I figured no problem. We installed my engine went out here on street tires with a possy and no POWERSTEERING!!! couldnt find a gs pump yet. My girlfriend was 6 months pregnant with my new born son and at about 20 miles an hour with the auto and 3000 stall and dropped low gear and opened the 1000 cfm barry grant carb all the way and look out. off both sides of the road, girlfriend sick in the car couldnt steer it quick enough no powersteering, down in the ditch. My friends car, not even close in horsepower. Si do your homework dont be a "Yeah my car is 400 horse, dyno and show the slips, read and weep!!!
Old 02-11-2009, 02:21 PM
65smallblock 65smallblock is offline
Theres an article on the webb (Chevy performance sight or ??) about taking a stock 400 and puting on a set of Vortec heads and a 4 bbl and badaboom, 400+Hp!
If its that easy with a 400 then Vortecs would be a good place to start with a 350. I woulld think that those heads with a well selected cam, intake and carb that a 350 could get real close.
Old 02-11-2009, 02:41 PM
oldbogie oldbogie is offline
Chevy High Performance several years ago took a Good Wrench 350 thru a series of step by step changes from the 230 hp it developed off the crate to well over 400 in modified form.
To hit 390 something they used Vortec heads, a Performer 2 plane intake with a 750 Holley, a Comp 268 cam, and 36 inch 1-3/4 inch headers. Porting the Vortecs took it to somewhere close 410. All this with the original bottom end which included these really crummy dished pistons with 4 valve reliefs. So assuming their numbers are honest, it doesn't appear that getting 400 horses from a 350 or a 400 is all that hard to achieve.
Bogie
Old 02-12-2009, 01:59 PM
American Muscle's Avatar
American Muscle American Muscle is online now
305 Turbo-Fire 240hp
I always go to gm performance parts and look at there crate motor techs and try to get parts as close to theres as possible. I have a 96 350sbc that I am building to match the zz4350 specs. The only thing its not going to have are aluminum heads but everything else pretty close. Theres even chepaer ways of getting 400hp without using nos. Just do a little research.
Old 02-13-2009, 11:34 AM
HonkeyKong HonkeyKong is offline
EQ 23 degree performance heads
Last edited by engineczar : 02-13-2009 at 06:58 PM. Reason: Advertising. Please see: commercial posting guidelines.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "400 horsepower??"
ThreadThread StarterForumRepliesLast Post
400 cid SBCShades_o_GreyEngine2002-04-2008 12:28 PM
Need some help building chevy 400pontiacpowerEngine602-20-2006 07:00 AM
Will my 400 engine/tranny combo fit?ChurchmanEngine401-25-2006 08:37 AM
400 SBC Balancing and info ?BrobobEngine810-31-2002 03:44 PM
400 327 cranklimeyEngine809-24-2002 07:53 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
