#1
400 horsepower??
what would be the fastest easiest way to achieve 400 horses out of a small block 350 the block is in great shape so what would be some build ideas for the cheapest 400 horses?
Register now (free) or login to remove ads |
#4
Where are you starting from as in what is the year of the engine and how is it configured. Pretty much 400 horse from a 350 is a no brainer, meaning not difficult to do. Bogie |
#5
The fastest way, supercharge it. You may or may not reach 400hp but it's about the fastest way to add significant amounts of power.
You could also fill your tank with nitromethane... (I'm kidding) |
#6
There's over 100 SBC engine combos on this site, 350's, 383's, 406 etc.. Have at it. You pick. Small Block Chevy Dynoed Combos http://ryanscarpage.50megs.com/combos1.html |
#7
Vortec heads
Beehive springs good for .550" lift full length headers Performer RPM intake Cam to make 400. Grin from ear to ear. |
#8
Ported 305HO heads, used performer intake with EGR (painted black), Quadrajet carb, long tube headers (painted black), upgraded HEI, and cheap E1785PM cam kit from competiton products.
It'll make 400hp, and look bone stock, not to mention can be assembled for less than 2G's if you do most of the work yourself and shop around. I have an engine very close to that combo but it's running a "Port O Sonic" intake (I thought it looked neat), a 2" 4-hole spacer, a 600cfm Holley (was free), and flat tops with ported 493 heads (those were free before I cleaned them up, ported, and replaced the seals and springs). |
#9
You are implying that you are actually making 400 hp with your combination. Do you have any dyno reports or track times to prove the 400 hp claim ? That does not look more than about 360 hp to me but maybe I am wrong. |
#10
Dyno reports? Why, the EGR and headers are probably painted black.
Who doesn't need a little Friday morning chuckle?!
''Life's tough, Pilgrim, and it's even tougher if you're stupid.''---John Wayne Midnight Sun Street Rod Association |
#11
I need to go out and paint my stuff now, the tracks are opening soon ! |
#12
I will post chasis dyno numbers once I get the truck completely together. Its the best I can do. FWIW DD predicts better than 400 on my combo, though I'll be the next in line to say that's not perfectly accurate. And I forgot to add 1.6 roller rockers (roller tipped at the least).
And the black paint is for stock look. It'll help hide the headers and make the intake look very close to stock. I have flashy engines and I have stock looking engines. I even have an engine that looks like it came out of a tractor. I like budget builds that look stock and can beat the flashy guy next to you. This is a great combo that is dirt cheap, has great midrange, a nice idle, and dances on both sides of the 400hp mark (depending on how you finish it up). |
#13
Some of those flashy guy's next to you might have just a little more than 400HP!
#14
What flow numbers are you using on your heads to get Desktop dyno to tell you that ? What are you using for an intake model ? I hope you do make a legit 400 hp but I am skeptical. I just went and fooled around with Desktop dyno. I can't get it to 400 hp. What are you using for compression ratio? I used 10:1. Last edited by RustoRod : 02-06-2009 at 12:06 PM. |
#15
For what it's worth we are running an all steel 1991 S-10 through exhaust manifolds. It has run 11.53 at 116.5. It weighs 3300 with driver. I think it is putting out about 405 hp. Your build doesn't look anything like mine.
| Thread Tools | Search this Thread |
| Similar Threads for: "400 horsepower??" | ||||
| 400 cid SBC | Shades_o_Grey | Engine | 20 | 02-04-2008 12:28 PM |
| Need some help building chevy 400 | pontiacpower | Engine | 6 | 02-20-2006 07:00 AM |
| Will my 400 engine/tranny combo fit? | Churchman | Engine | 4 | 01-25-2006 08:37 AM |
| 400 SBC Balancing and info ? | Brobob | Engine | 8 | 10-31-2002 03:44 PM |
| 400 327 crank | limey | Engine | 8 | 09-24-2002 07:53 AM |
