400 - M - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-29-2008, 09:45 AM
Mr.Fixxit's Avatar
400 - M
Hello, I have a 1974 Mercury Montego MX, it is a very nice car, it handle well, and all of the above. But, it has an original ford 400 2V engine. And, i can't get any real information, off the internet. Nor can i find any books with specifications on the motor. I was hoping some of the members here could give a little bit of info of what i'm Working with. Thank You.
Old 12-29-2008, 10:02 AM
Google "Ford 400 engine" and lots of things will pop up.
I had a 73 and a 75 when new.
Basicly it is a low compression 402 cubic inch engine with open chamber heads (about 8.0/1), retarded camshaft timing, and retarded ignition curve, catalytic converters, designed to pass the archaic smog rules.
Rated about 160 hp in the new net rating system.
Simple inexpensive upgrades that work are
a 70-71 cam timing set, which advances the camshaft about 8* and adds a noticable 20 to the power curve.
Recurved ignition timing curve with functional vacuum advance, (needs a true Ford man to accomplish)
free flowing exhaust system without cats.
If you are into cam changes, the 4x4 cam from CompCams is good.
I have a 400 M for a 76 sitting here now, in limbo, waiting for the owner's decision as to how much oooomph we are going to put into it. $$$$
Old 12-29-2008, 10:41 AM
Here is some info on the Ford 400 M http://www.activeboard.com/forum.spa...picID=22182563
Old 12-29-2008, 02:00 PM
cboy's Avatar
Last journal entry: Finished
http://www.fordcobraengines.com/Modified%20History.htm
http://www.projectbronco.com/Technic...the_rumors.htm
http://www.ford-trucks.com/forums/30...omments-2.html
Always learning...and sharing what I've learned.
Old 12-31-2008, 08:00 PM
Occupant Ilied Industries
http://web.archive.org/web/200712261...250/index.html
Also has extensive information on the Motorcraft 2150 carb...this is an archive.org archive and may be incomplete.
Old 01-02-2009, 01:53 PM
bullheimer's Avatar
NEVER use credit cards!
gee, just read the new PHR magazine on the Engine Masters Challenge. there are 5 400M build ups in there. seems like you have what must be THE best engine God ever created!! won the contest two years in a row and finished in the top 4 of 7 spots this year!!! all you need is the chevy rods, custom pistons, CHI $$$ cleveland heads. etc etc & like $20000.+
who says you can't polish a turd?
Old 01-02-2009, 03:17 PM
Wiki Edits: 27
m heads
the M production tooling got shipped to austrailia. Google australia 400 ford they designed new heads that did not have to meet us epa reg's
Old 01-03-2009, 06:04 PM
Actually they are pretty good engines. They just were born (like the 400 chebby) at an inopportune time.
There have been several pretty good ones built and driven over the years. Just think if the 351 Boss or Cobra Jet had become a 400?
400 cid SBC Shades_o_Grey Engine 20 02-04-2008 12:28 PM
a budget 383 stroker build using a stock 400 GM Crank Mustangsaly Engine 7 10-15-2007 12:57 PM
my turbo 400 won't shift!! skylark65 Transmission - Rearend 2 07-01-2007 07:58 PM
383 or 400?? KFXrider88 Engine 7 06-13-2006 05:45 AM
400 Combinations MI2600 Engine 15 05-12-2006 07:08 PM
