400 mains inner diameter 2.82 inches?
ok so the block i have has 2.82 on the journals and factory 400 sbc was 2.65? I believe... Its been line honed? The rear and front main look all right its just i mic'd it out and it said 2.82 on both... Wander if its safe or junk to even line bore it anymore, machinist said it had to be bored with new splayed caps... Of coarse when he looked at me he just said it was just needing line honed, and then i told him it had after market caps he started racking me with fees. It hasnt been done yet but im wandering if the block is safe past this mark, soon itll be 2.90 and i was also wandering if they even sell main bearings for this kinda thing
I got to the shop and checked the books.. Crank OD is 2,6484/2.6493"
You must be measuring incorrectly as. 400 housing bore spec is 2.8406/2.8415". If your block measures this, it's OK, if larger it has been cut for larger OD bearings, As mentioned these would be repair bearings not available in many common ID sizes. Or the block has been in the hands of a rebuilder such as Jasper. These guys use every block that come thru and use custom OD bearings to fit their final size.. You and I can't get them.. Makes for real fun if the block needs another build after they get thru with it,, Also have fun getting a rear seal that fits.. Been there.. Last edited by BOBCRMAN@aol.com; 01-17-2012 at 01:15 PM. |
O thank god, thank you for letting me know that it is suppose to be that exact measurement. Just a few off i suppose.. Its stock then right? The main housings did measure 2.82 i geuss its a lil small
Not that i was trying to put the machinist down either, the guy was new to me and i dont know much bout there buisness, i coulda been getting ripped off. They were real jittery about racking the fees looking at one another and shaking there heads real funny... Its like they were paranoid. |
| Pontiac 2 bolt mains changed to 4 bolt mains | eztuld | Engine | 7 | 12-11-2010 04:12 PM |
| Cylinder diameter VS. piston diameter | XeroVolume | Engine | 32 | 09-05-2010 09:31 PM |
| 454 mains | ekacpuc | Engine | 3 | 05-10-2010 09:36 PM |
| 400 sbc mains | Johnny's 67 Camaro | Engine | 17 | 03-05-2008 06:43 PM |
| 383 Mains | Mightymouse | Engine | 13 | 07-13-2004 10:37 AM |
