Engine Building 101
The 400 is a great motor, hold on to that one.
If you know the motor is good to begin with you really don't have to have all that machining done to the engine. I might have them Bake the block and Jet the engine block (Clean), Magnaflux and then Deck the engine block surfaces .010-.020 Alot of the changes that your talking about require alot of work. Here is a set of heads and camshaft to use with the engine that will give you good perrformance and really peaky performance and lots of low end torque for burning rubber. Flat Tappet cam GMPP PN#24502476 110 lobe seperation, I:435, E:460 Fast Burn Heads GMPP PN#12464298 .530 max lift, Dual intake bolt patterns for vortec or older pre-86 engine intakes and dual valve cover bolt patters for both center bolt and perimeter bolt covers. 1.6 Roller Rockers PN#12370839 changes lift to I:.464 E:.490 (Self aligning), (Note: That you'll need rockers covers to clearance the added rockers 1.6) Valve Covers PN#12497978, Added clearance Gasket Kit PN#88958694 (head gaskets, oil pan gaskets, crank seal, intake gaskets, valve cover gaskets, outlet and fuel pump gaskets, and distributor gaskets) Note: Other parts will be needed Intake PN#12496820 (Dual carb patterns, vortec pattern, EGR passage, High flowing, Dual plane(All around performer of the torque and HP curve)) Have a blast, do you homework. |
moving to engine forum
Ontario Rodders |
As far as heads go, I'd find a large chamber (72cc-76cc). Depending on how much you want to spend, will make a big difference in what you're going to get. If you're keeping it in your Caprice I would not put too big a runner on. A buddy of mine has a 406 in his '84 caprice with AFR heads etc etc etc, and it runs 10.0x 1/4 mile. Too funny. Anyway, keep your intake runner in the 180-200 with a dual plane intake, an HEI would be fine. The 400 is a forgiving motor in the cam department for what I think you are looking for, and I have done them in big bombers like yours with 218-228 dur / 450-480 lift / 112-114's with very good results. The fast burn heads will work but you will need a rather large dished piston with that 62cc chamber. You can find good, or better heads for less, or little more than the GM units. IMO, if you are having the block machined, it might be a wise choice to get the whole engine-lada, and bore the cylinders too. I can't see that as costing you much and would insure a better overall build. Then, you can get pistons that'll work with a 5.7 rod - if thats where you want to go. Talk to your machinist about this first as your cylinders may be OK. What kind of budget are you working with? I had a '72 Impala with a warmed up 400 and it was a whole lot of fun. I ended up yanking/building that motor for a '79 camaro, what a rush!.
I agree on the shortblock recommendation. Do a compression test If you get pretty even compression across the board, keep it as is.
Once you disassemble it, it almost has to be overbored. Putting new rings in an old bore is kinda like putting new lifters on a flat tappet camshaft. Over those 80k miles you have altered the shape of the bores. They likely have taper, runout, and are eggshaped by a few thousandths. The rings have worn with them and retained seal... that's their job. Puting new perfect rings in used bores often times makes a very poor seal. Even if you document where the old rings came out and re use them, the chances of getting a good seal are very slim. Its one of those things where if you're going to the trouble of disassembling it, its $30 to tank it which requires cam bearings for $50. Then an overbore is only $150, new pistons are pretty cheap, new rings aren't bad.... pretty soon you've remanufactured the entire block for $600. But, like has been said, if its fine - its fine. Use it as-is. There is no benefit to tearing it all apart if nothing is wrong. Last edited by curtis73; 05-24-2008 at 02:13 PM. |
On the rods; its not the crank you have to change, its the pistons if you want longer rods, but rod length has shown to have very little effect unless you're finely tuning this for race. Quote:
I've also used Mallory distributors and disliked them greatly. The shafts on their billet HEI have so much flex I lost 2* at redline. I know it wasn't the mechanical advance malfunctioning because it was welded closed. Avoid Accel products in general. MSD makes good stuff. I've never used their distributors, but hear good things about them. Quote:
The vortec head would work nicely on a warmed-over 400 with a very mild cam. They would run out of breath at about 5000 rpm, but that's a heck of a lot more than you get now. Last edited by curtis73; 05-24-2008 at 02:41 PM. |
| A quick question about titles and legal stuff. | rusty105 | Hotrodding Basics | 71 | 05-04-2007 09:13 AM |
| Turbo 400 rebuild for a blower motor | Bad Rat | Transmission - Rearend | 1 | 03-28-2007 12:24 PM |
| emision loopholes | digitalfrek | Engine | 13 | 03-13-2006 06:25 PM |
| Mouse Motor 305 differences | atlantis | Engine | 1 | 01-19-2005 12:56 AM |
| 400 turbo Trany with a 350 motor | BowtieBubba | Transmission - Rearend | 5 | 12-12-2002 08:05 AM |
