please ignore this thread.
im building a '77 omega and ive found a borg warner rock crusher 4 spd to put in it but i need some beef to turn it. i found a pontiac 400 and i was wondering if a pontiac 400 and a chevy 400 were the same and is it a big block or a small block cause a 400 is right on that line. sorry i didnt mean to make 2 post! i got lost.
Cole |
rock crusher
ive been told that its a borg-warner but ive not picked it up although i have been told that they have not been made since the eighties. ive also had some old hot rodders tell me that muncie never made the crusher it was borg but all the same visa-versa
In "old hot rodder" circles, Borg Warner is known for the T-10 4-speed and variants. Muncie is known for the M20 wide ratio 4-speed, M21 close ratio and M22 close ratio "rock crusher".
Google it. |
Better find a trans ID guide to take with and make sure it's not a Saginaw. I don't know how many people have told me that they had a Borg Wwarner T-10 or Muncie "Rock Crusher" for sale and it turned out to be a Saginaw. |
d73
the transmissoins will not bolt up probraby more horeses in the pontiac
Let's start at the beginning. First, the Pontiac and Chevy motors are completely different designs with different bore, stroke, castings, and bolt patterns. The motor mounts are different. The bellhousing bolt patterns are different. The accessory brackets and locations are different. The exhaust manifolds are different. The starter motors are different and are on opposite sides. The only thing they have in common is the distributor cap!
The Chevy 400 is in the small block family. Pontiac motors have all one family (excepting 301s and 267s with their shorter deck height) so there is no big/small block distinction. As for the trans, the BELLHOUSINGS are different, but with the correct bellhousing, you can bolt any GM-compatible trans to either motor. |
pontiac.
ok im going with the pontiac 400 and as for the trans some one is picking it up on there way through okc but it was 75 bucks and if it explodes after puting it in ill just get a different tranny plus i have a buick trans in the shop that looks just like the pontiac trans siting next to it. the buick tranny being a good one and the pontiac having huge holes and cracks all over.
thanks for all the input, i will up date on the 4 spd |
The transmission should bolt up to the bell housing with no issues. A Chevy bell housing will not bolt up to a Pontiac engine and visa versa. The standards were pretty much interchangeable back then. The only issue will be to get the right spline and pilot bearing for the clutch and crank up front and the correct yolk and drive shaft length for the back.
The rock crushers were called that because they were noisy due to the straight cut gears. The straight cuts were supposed to be stronger. The m-22 is easy to work on. I rebuilt a few back in the day. The BW transmissions were not bad either but everyone wanted a Muncie
Artificial Intelligence is no match for Natural Stupidity Chet |
The m20, m21, etc are rpos I think had more to do with being close and wide ratios. My old boss had a 79 camaro with a factory 4 speed it was a super t10 and had the m21 rpo on the option sticker. Muncies supposedly didn't come in vehicles past 74 or 75 but some Canadian cars received them later on. I guess they were using up old stock.
| Pontiac 400 vs. Pontiac 455 | chevyelc81 | Engine | 7 | 03-19-2011 07:31 PM |
| 400 sbc vs 400 pontiac | Artemis Entreri | Engine | 52 | 09-08-2010 06:17 PM |
| 400 pontiac and 400 chevy?are they the same? | 77'Omega | Engine | 5 | 06-15-2010 05:51 PM |
| Pontiac 400 Running HOT | zipfactor | Engine | 4 | 08-07-2009 08:28 PM |
| Pontiac 400 running hot | zipfactor | Engine | 35 | 07-11-2009 09:12 PM |
